Boy it's warm in the workshop today, the engine is a tight fit but is starting to take shape.
Last edited by Phil Woollard on Wed Jun 24, 2020 4:27 pm, edited 4 times in total.
- Has liked: 794 times
The pulley and idler came out good. How did you simulate the flat belt?
Your cading is brilliant my friend! The belt is just plasticard until I can find a suitable vee belt, I wonder if printed very thin it would be flexible enough ?
When it's painted black it should look really convincing.
- andymusgrove
- Has liked: 198 times
- Been liked: 89 times
Fantastic work Phil and Vince on the Cad
Phil what did you make your wiring couplings from if i might ask please - they look great.
Andy
Andy
Thanks Andy, Dave at Armorpax cast me around forty of the plugs, the flex is braiding on a roll with stiff wire inserted, it takes for ever to put them together. I wish I had another forty, so Dave if you get a minute mate?
- Has liked: 116 times
- Been liked: 1106 times
A minute?????????????????????????????????
www.armorpax.net
How many question marks lol. Any luck with those doss bags for the rear bins Dave?
It makes your back hurt bent over the engine bay all day but it's coming on.
Is this OK for the exhaust manifold before I make a mirror copy for the other side?
I made them with a smooth transition from square section to circular section. I sent you an image with the transition having a flange but it seemed to rough on the eye. If you really want it with the flange hopefully I can go back and add it.
I made the drawing as close as possible to your sketch but I have a gut feeling that there is something wrong.
That looks very nice indeed, I did like the top flange as you can see it when you lift the radiator, and it breaks up the long run.
Let's give it a go!
I have another two hours on the blast deflection plate then that's all four quarters done, then I will print them out.
The only thing that might not be the same as the 1/1 is the outlet distances of each port, they look more equally spaced on this photo but that doesn't mean the headers followed the openings, they may have been angled?
Let's give it a go!
- dcab3f7a-20e2-4c3d-a926-a5e200ee7578.jpg (123.36 KiB) Viewed 88946 times
How's this now?
Are you sure you have enough vertical space to fit it to Ivano's engine?
That look more interesting, I like it Yes plenty of room for that engine but there won't be a mm spare lol.
Received and printing. Thank you my friend
