Good luck with the drilling and grinding Charles, thanks for the heads up with the build Mark.
I have found it pays handsomely if you read and scrutinize the instructions throughout each time a new piece is fitted or section completed.
where's the part and when should I fit it?
(Front casting lifting lugs)
I'm trying to improve the front top casting at the moment. (I'm waiting for parts for the exhaust box),
So I thought I'd get on with "Chiefy Mc Tank face" as I call it.
I have increased the definition of the front lower armor plate earlier to generate a more prominent center line by about 7mm across the front arc, now is time try and match the lower plate to the upper front casting.
The idea was to make a complete nose plate, pin and glue to the front, (plan A), sounded easy in my head.
Carved up an old fishing rod rod rest spike and ground the general shape. It looked good at first, but it was just too big and it needed a filler plate and a good dollop of P38 to complete. That's going to happen.
(Plan B) Grind off the top lip of the added armor plate and shape the single nose piece to match the upper armor casting and lower armor plate.
This, I think looks a lot better, it has the curve that I wanted to achieve between the two plates. There's still a need for a bit of filler along the joint line, but no where near what was originally considered.
There's a way to go yet, final fit when the upper cast plate is finally bolted in.
To most it might seem like madness, but I'm trying to recreate the curves and shapes that I think I need to see on the model.
During this grinding period, I thought I'd fill in the upper casting lug points which are not sited in the correct place, They will have to be re positioned at a later date. I'll be plugging and tapping some of the other mounting holes too so I can hold down the brackets with smaller bolt heads and not nuts on treads.
- SAM_2374.JPG (180.33 KiB) Viewed 2651 times
- SAM_2420.JPG (242.91 KiB) Viewed 2651 times
- SAM_2430.JPG (191.47 KiB) Viewed 2651 times
- SAM_2443.JPG (182.84 KiB) Viewed 2651 times
- SAM_2445.JPG (174.48 KiB) Viewed 2651 times
- SAM_2468.JPG (182.69 KiB) Viewed 2651 times
- SAM_2459.JPG (174.29 KiB) Viewed 2651 times
- SAM_2461.JPG (175.74 KiB) Viewed 2651 times
- SAM_2456.JPG (185.71 KiB) Viewed 2651 times
