Resilient wheels
Bryan Waterloo
Has liked: 6 times
Been liked: 10 times
Resilient wheels
Post by Bryan Waterloo »
How is the spacer CP0340 used in the wheel assembly?
Directions mentioned it’s use, but nothing on how to use them
Phil Young
Has liked: 40 times
Been liked: 59 times
Re: Resilient wheels
Post by Phil Young »
Any help Bryan?
Bryan Waterloo
Has liked: 6 times
Thanks Phil, yes it does. I figured that might be the way
Bryan Waterloo
Has liked: 6 times
So, what’s the torque rate on these. The one I completed I spaced the bolts like a car tire. So they are evenly tightened. However given the rubber gasket I’m not sure if you over tighten it’ll be a issue, same for under. That rubber ring does compress with the right amount of pressure. Currently I have a paper thin space between the disk ( CK0215) after cranking down the bolt...is this the right approach? Not sure at this point and don’t want to move ahead with not knowing the proper assembly
Phil Young
Has liked: 40 times
Hi Bryan
I tightened mine the same way as you. I’m pretty sure the two metal “discs” are touching each other when the nuts are tight. I used 45 years experience as a mechanical engineer to gauge that they’re tight!
RChianese
Been liked: 11 times
Post by RChianese »
My CK0215s touch for what it is worth. I started to develop a routine on about the 3rd wheel. When I get to 35, I will probably have it perfected enough for the finale!
Robert
"He who dies with the most toys wins!"
Bryan Waterloo
Has liked: 6 times
Thanks for the reply’s and info, sorry for the delayed response! I think all 3 of us are assembling them the same way, pretty solid once completed...only have 26 more to go!
Thanks again for the help.
Phil Young
Has liked: 40 times
Hi Bryan
You’re welcome. By the way, I only have 6 to go... just saying!
Phil.
Adam Osga
Has liked: 107 times
Been liked: 91 times
Post by Adam Osga »
Has anyone gotten any official word on this from armortek?
Phil Young
Has liked: 40 times
Hi Adam
It just seems the obvious way...I can’t see any other way of assembling them?
Phil.
AlastairCooke
Has liked: 16 times
Been liked: 776 times
Post by AlastairCooke »
Hi all,
I am thinking of replacing my late pattern Tiger 1 wheels with a set of the new resilient wheels supplied with the KT and upcoming JT kits. Does any one have any advice based on fitting these to the 2019 KT? Many thanks and stay safe
Alastair
Alastair
Tom Miller
Been liked: 347 times
Post by Tom Miller »
Is anyone painting these assemblies before assembly? I am concerned about the steel rings rusting on the inside. How about a coat of primer on the inside surfaces before assembly? Overkill?
Thanks,
Tom
Has liked: 1492 times
Been liked: 1699 times
I give anything steel a coat of a high zinc content primer and anything aluminium a mist of etch primer followed by a normal acrylic primer.
Adrian
