New muzzle brake
Ivano Costantini
Been liked: 735 times
New muzzle brake
Post by Ivano Costantini »
Given the interest aroused and the orders already received, I thought it appropriate to create a specific topic for the muzzle brake.
After corrections and modifications, this is the definitive model.
It is 3D printed with a machine that uses nylon as a material. It is a very resistant and easy to handle material to work with. I used the "Tiger Info 1" dimension and saw many photos, so it should be like the original. I also created a piece of ribbed cane to insert. It is composed of 6 pieces. Only a light sanding with thin paper and therefore 1/2 passes with putty spray is necessary to eliminate small lines.
with and without putty
This is the product I use
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: New muzzle brake
Post by Steve Norris »
Hello Ivano
You have created a wonderful looking muzzle brake.
Can you tell me is this the large type found on early and mid production Tiger 1 or the smaller type found on late Tiger 1 and Tiger 2.
Ivano Costantini
Hi Steve,
if the information and measurements I found and used are correct, this is for Tiger1 at the beginning and in the center.
You can notice the differences in these photos
The first on the left is the original Armortek, the second is that of F.O.A.( late and Tiger II)
the third on the right is mine.
I'm not sure if the barrel lines rotate left or right.
On a 1/6 scale, the difference is almost imperceptible, however at the moment I provide both DX and SX. When I am sure, I will only deliver the correct one.
Steve Norris
Has liked: 8 times
Thank you Ivano.
Definitely a worthwhile upgrade. I will be ordering one when they become available.
Ivano Costantini
They are available, I have already started to ship.
For the cost, contact privately, thank.
Ivano Costantini
I was canceled a muzzle brake order,
the package is ready for shipping, can anyone care?
Thank you!
Advances should always be requested even for small prices!
Steve Norris
Has liked: 8 times
I have just received my muzzle brake from Ivano and would highly recommend it, a superb piece of 3D printing that will add greatly to the look of my Tiger when finished.
The finished 3D print is excellent and does not appear to need any further work.
Has liked: 2282 times
Been liked: 7196 times
Ivano is there any chance that you can supply the rifeling for the Chieftain muzzle? 8)
Ivano Costantini
Hi Phill,
the translator doesn't help me, I don't understand what it is.
Can you post a photo?
Thank you!
Ivano Costantini
Hi Steve,
i'm glad you like it.
I hope others like it too.
This end, the rifeling
Ivano Costantini
Phil, it shouldn't be a problem,
however it is necessary to have all the measures: length, diameter, thickness, number of lines, a drawing to understand how it fits on the gun barrel and so on. If someone takes responsibility for going to the museum and taking these measures or if they already have it, I can try.
Ciao!
Cool, someone will help I'm sure and lots will benifit. 8)
Jack Hrovatin
Been liked: 52 times
Post by Jack Hrovatin »
I have ordered a Muzzle Brake from Ivano, and look forward to receiving it. His work is great, and he is very trustworthy to do business with. I’ll advise everyone of my thoughts once I get it. I’m glad someone is working hard to correct so many deficiencies with these kits!
Ivano Costantini
I spoke to David Byrden,
confirmed that the muzzle brake lines turn left (clockwise). The new muzzle brakes that will be ordered, as I have already anticipated, will only have this piece. Those who have already purchased them now know which one to assemble.
Thank you Ivano
