New engine for King Tiger and Jagdtiger
Michael Röder
Has liked: 79 times
Been liked: 113 times
Re: New engine for King Tiger and Jagdtiger
Post by Michael Röder »
Thank you Ivano for the explicitly answer and expressive arguments.
I will come back to you and wrote you a PM.
Ivano Costantini
Been liked: 735 times
Post by Ivano Costantini »
On this topic, it would be interesting to read the opinions and ideas of those who have already assembled the engine. I hope someone wants to participate in this interesting discussion. Thanks Ivano
i have a Ivano Engine, they are a work of art and too good to chop, they are a stand alone model in them selves, you need to make an engine compartment that will slot in and out of the tank, so you can enjoy the engine detail when not in use, or a less detailed top half of an engine that can only be seen with the deck hatch open, these mods do enhance the models, regards simon manning.
Ivano Costantini
For now only primer
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
I have one of Ivano,s engines and can highly recommend them. I have only assembled the MDF frame at the moment and everything fitted together perfectly. As Simon said, I wouldn’t chop the engine in half as it’s to good a product to spoil in this way.
When I get round to assembling the rest of the engine I will post some more details of my build.
Ivano Costantini
Left side:
i'll show you what you should never do, I've always said and keep saying that before gluing you always have to check many times that everything is aligned. I didn't do it and that's the result
also, I forgot to insert the pins !! ??<br />what are you up to Ivano?
I have not correctly aligned the four brackets, and the cylinder does not rest correctly
the oil cooler supports are almost perfect, just a small change in circumference, careful not to damage the holes
Ivano Costantini
The correct assembly sequence is as follows:
mount the pins on the brackets, do not glue
oil cooler, large cylinder
DSCN2517 (2).JPG (40.3 KiB) Viewed 2132 times
DSCN2516 (2).JPG (32.05 KiB) Viewed 2132 times
rest the brackets and align with the help of the cylinder<br />only when everything is perfect, paste
Ivano Costantini
The sirocco fan is almost finished, I will complete it later.
Now, I will skip the assembly stages of those engine components that have no particular difficulty in assembling. It is very difficult to make mistakes because all the pieces are packed with their respective bolts. Anyway, if you have doubts, ask me.
Try to center the flywheel well with the fan and cover.<br />Mine is not perfect, but once finished and closed, you will not see anything.
I haven't put the bolts on the lid yet
This terminal must be shortened to the correct size, I don't have a tank, so I can't do it.
Ivano Costantini
One thing that differentiates the P45 from the P30 are the vertical collectors of the exhaust pipes. Here are the main pieces that make them up, only the corrugated pipes are missing. They came out well, I like them, what do you say?
Ivano Costantini
Here's how it looks mounted.
If you think that's not good, make comments.
Thank!
Ivano Costantini
this is the top of the tube
Ivano Costantini
Before placing the drain pipes, I preferred to paint them. Before joining them, check that everything is aligned, check that the false support brackets enter the holes and housings. Also check that the covers have space to slide both above and below. Before gluing, test the entire assembly. Pay attention to the covers, they are thin, therefore a little fragile. Before putting the covers on, put the pipe ends.
The lower left cover must be cut in this way.
Ivano Costantini
Left exhaust, I don't have the tank, therefore I don't know the length of the vertical pipes, each one will have to cut them as required by the engine compartment.
Ivano Costantini
The right drain is also positioned.
It is necessary to slightly lower the upper side from the flange.
Ivano Costantini
Completed and painted with wear and aging.
How do they seem to you?
