Faux tool latches - how too 101
Has liked: 125 times
Been liked: 755 times
I thought I would share a simple technique to make reasonable (I think) looking but non working, durable (Pseudo-scale) tool clamps for detailing our models. The clamps are primarily for German vehicles although allied vehicles used clamps like this as well.
This is not intended to be the end-all way to make these, but a simple guide for those who want to experiment. These clamps are also only intended for scrutiny at standoff distance (3-5 feet for me) not the ultimate in 100% accuracy. One final note, while there is no substititute for real working latches for ultimate wow factor, some may prefer a not so delicate (or expensive) alternative to real working latches. Those short of cash to buy real ones (like me) or who like to tinker (also like me) and who don't have the patience to make real latches (yup like me :oops: ) may find the following article useful.
First the tools:
Simple set of hand pliers and a pin punch (for a mandrel) is all that is needed to form the clamps. Of course a sheet metal shear (to cut strips) a soldering torch, files, jewelers hand saw, and small hammer are also handy.
The pliers:
A) Pin punch -aka round bending mandrel
B) Chain pliers - smooth round jaws, for making curved bends
C) Flat jaw pliers - for 90 degree bends, jaws are smooth, no teeth to scratch sheet metal.
D) Needle nose flat jaw pliers - for 90 deg bends, and narrow bends, jaws are also smooth.
E) Cutters
Materials:
Aluminum, up to .020" thick, easy to work, soft, cannot be soldered easily, looks good when paint chips off (like steel).
Tin, up to .020" thick, used in this example article, soft, easy to work, can be soldered, looks good when paint flakes off.
Brass, up to about .015" thick, harder than alum and tin, can be soldered, doesn't look so good when paint chips, but my prefered material as it holds it shape better than alum or tin.
How to:
1) Cut or buy strip to size preferred. Make square ring from .03 brass wire using "D" pliers to form ring. Strip should just fit between ring.
Making nice looking square rings takes some practice and trial and error - I still have not mastered it yet.
2) Form a tiny 90 deg lip at the end of the strip using either "C" or " D" pliers. Then form strip into a "U" just slightly wider and higher than tool to be held in clamp.
3) Using pin punch as a mandrel, bend the end opposite the lip formed in 2). The tops of the lip and bend should be approx the same height.
4) Place ring into curved bent region, and trim off excess materials using cutters (E). Place nipped ends of ring into trough of strip so that the cut ends will not show.
5) Fold material around ring with flat pliers to trap ring in place.
6) Select another strip of material the same width as your first peice to be the cover strap. Bend a lip in one end using flat pliers and a third piece of material to gage the thickness of the lip. The material should just fit into the bent lip.
7) Using the chain pliers (B) and pin punch mandrel (A) bend another curve in cover strap. Use the tool bracket you just made to gage the size. Trim off excess material once cover strap is correct length.
8. If you bent the metal correctly :P the cover strap should snap in place over the bracket and stay in place. This is a bit challenging to get right, but tin can be bent and unbent until you get it right. tin is quite soft and deforms easily so don't give up - you can always start over :evil:
9) Heres tool bracket parts prior to being soldered together.
10) Once soldered together the piece can be test fit to the vehicle (Panther in this case). There is a flat head screw just behind the axe that holds the bracket in place. The "L" shaped brass piece will help hold the axe in place as well.
11) Dissassemble, prime and paint your piece and re-install it. Then stand back and admire your work! 8)
Enjoy , and give it a try!
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Robert,
Excellent post and the clamps look very good. I agree that working is the best, but for those that only need or are satisfied with the 90% solution then this is the way to go. I also think that there is much more satisfaction in making ones own as apposed to buying, plus there is the added bonus of developing ones skills.
Allan Richards
Thanks Allan,
I tend more towards durable than 100% accurate on big stuff like this. Big tanks shouldn't break easily!
Perhaps someone really talented like Steve Norris, Steve Winstone, or Mike Stannard could school us on how to make real latches! Sorry to drop names guys! Hint hint!
JWFGoode
Post by JWFGoode »
Nice job Bob!
Which beasties do you have running?
Hey John, Good to hear from you! Sadly none are running yet, although the Panther is getting really close! Maybe by Christmas?? :roll: I spend too much time tinkering on the outside details... :oops:
Hows the engine business? Have you tried casting yet?
JWFGoode
Post by JWFGoode »
You & I will try some casting later on, but it's too busy with work & motors right now!
My Tiger runs fine, intercepts a lot of interference so watch your toes as it likes to lurch without notice. On the cement floor of the basement it has enough torque to spin the treads if you give it full stick. Not especially a very fast top speed but it will climb a tree if you let it. Will also make a couple of new 5mm torsion bars at a higher locked angle to lift up the rear as it settled just a bit. Usual stuff. Keep up the great work! happy building
Rich Stinchcomb
Has liked: 3 times
Been liked: 1 time
Post by Rich Stinchcomb »
Well done tutorial and great information for the DIYers. Thanks for taking the time to post.
"All you saw in your imagination was the muzzle of an 88 behind each leaf." - British Tank Commander Andrew Wilson
Hi Rich, glad you enjoyed it. You've been quiet for a while!
