Chieftain Prototype Build
Has liked: 1040 times
Re: Chieftain Prototype Build
The GUE or “genny” was essential to start the Main engine. Thereafter, in theory you could switch it off and the ME generator would sustain the load. In practice we never ran on ME only out of choice. More usual was to switch off the ME and use the GUE whilst the radios and gun kit were operating. We could then go to a silent watch, as long as you didn’t need the light projector. I’m sure Mark will comment more knowledgeably as wiggly Amos was his trade.
Manny Leung
Been liked: 83 times
Post by Manny Leung »
Does a chieftain engine sound the same when running on diesel or petrol? Or can you tell by the sound which fuel it is on?
Manny, I doubt there are many people alive who have ever heard an L60 running on petrol. I certainly haven't. In a couple of decades on the tank, I never filled up with anything other than diesel. The biggest element in the overall sound of the engine is the exhaust note and that isn't dependent on fuel. I can't think of any reason why the choice of fuel might affect the sound of the tank, unless you tried using chicken s..t.
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Post by Kevin Hunter »
That really is an amazing sound, I hope the electronics can do it justice? Looks like the smoke generator(s) will have a bit to live up to as well :-)
Kevin
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Post by Mark Heaps »
For Vince & Stephen,
The crews were taught to start the GUE first as best practice, the coolant would start circulating to pre-warm the ME and the output from the GUE would reduce the load on the hull batteries when starting the ME. The hull batteries were four 100 AH in a series paralell configuration to give 24V 200 AH. If the hull batteries were in good condition with a good state of charge, the ME could be started without the GUE running and on-line. The GUE was not essential but it was good that the crews thought it was, it re-inforced best practice.
Theoretically the GUE could have been switched off once the ME was started and the ME Gen on-line, but there was no reason why you normally would want to do so. Having both generating systems on-line, either of them could fail and it would not affect the fightability of the tank.
The only reason I can think of where you might shut the GUE down after having started the ME, is if the GUE had a coolant, fuel or oil leak and you were using it for the shortest period possible to get the ME started.
Has liked: 794 times
Thanks for the info. I thought it would be used similarly to an aircraft APU but it seems I was wrong.
Mark Heaps
On Chieftain, the GUE generator was rated at 150 amps and the ME generator was rated at 350 amps. If both systems were on-line, the generator panels did load balancing so each generator would be proportionally loaded to get the total output required.
Challenger 1 & 2 had higher rated GUE generators, the generator panels would work to load the GUE generator to the max before loading the ME generator to cover any excess required. Any electrical load on the ME would mean less power for automotive purposes.
If I recall correctly, the GUEs only got the designation APU´s with the introduction of Challenger 1 to differentiate between the two fits, ie a Chieftain GUE would not fit in a CR1, and a CR1 APU would not fit in a Chieftain ARRV. Both vehicles operating side by side.
Been liked: 3713 times
Rubber inserts for the Chieftain tracks getting counted out and packed.
A few more photographs of the Chieftain.
It’s impressive, superb even. Looking forward to seeing it, if not hearing it at the Open Day. Some hull back bins would fill a space or two.
mark lawson
Has liked: 2520 times
Been liked: 445 times
Post by mark lawson »
This is certainly Armortek's finest model thus far.
RAG Militärmodellbau
IG Militärmodellbau
Been liked: 1842 times
WOW :shock:
Stephen White wrote:
Mon Sep 09, 2019 7:14 am
.............. Some hull back bins would fill a space or two.
They are on the production version, but not the prototype. Same with the ribbing on the bins.
Kevin Hunter
Phew !! :D
And the bow wave deflector ?
It looks awesome. Well done to all involved.
Kevin
Gerhard Michel
Has liked: 3 times
Been liked: 690 times
Post by Gerhard Michel »
Just some thoughts about tank engine sounds and their reproduction in models like 1/6 scale:
1. A real tank sounds very differently at front, side or rear view when passing a person. A model with its sound source down below cannot reproduce these different sounds for a listener. Therefore it is a little tricky to find a suitable sound pattern for a model
2. Loudspeakers can reproduce the deep frequencies of tanks and their engines only with large dimensions which don't fit a model. Therefore it is better to use one big speaker than two smaller ones. Unfortunately most amplifiers are 2-channel-types which don't allow to use their 2 channels parallel at one speaker. Using only one channel results in half the output power. A possible solution is to use a speaker with 2 moving coils, another solution could be a dedicated car amplifier with a subwoofer option to bundle two channels to one.
3. To compensate the lower effectiveness of a small speaker at low frequencies it is possible to intensivy these frequencies previously by audio processing. Unfortunately this procedure also encreases the power consumption. A tank engine sound in a model, reproduced close to the original, has a power consumption which clearly exceeds the main engines! Therfore a seperate power source ist necessary for the amplifier, needing additional space.
The best (and loudest :twisted: ) reproduction of a tank engine sound I ever heared was Olaf's Panther in 1/4 scale with a 40 cm subwoofer, 2.000 watts power amplifying and a 40 Ah power source only for the sound! But with its 100 Ah driving power the model runs significantly longer than it sounds........:twisted:
Gerhard
