Phils Famo build
Re: Phils Famo build
Hi Florian, ref the L/A, it requires the standard receiver voltage of 4.8v. I have measured 5.7v from my receiver and it's happy on that . It works just like a servo and is self centreing. It has the standard receiver 3 pin plug, it requires the input from a standard receiver to operate correctly ie a proportionate channel as stated in the motion manual, they suggest the rudder channel. I can not see any labelling so am not sure of it's current/amp requirement, so just plug it into your receiver and play! I think that covers the "exit pin" question as well?
Not sure what motor you are referring to but I would think it's the main drive motors, the Armortek motion control module uses a single 60 amp fuse, this covers both motors...……...Phil
- Has liked: 297 times
- Been liked: 645 times
hi Phil,
Thank you for the answer. 60A for both engines. Then a 30A regulator is enough.
Thank you for the info regarding the servo. So I can make it my way, perfectly
Florian
Florian
- Been liked: 3 times
Hi Phil,
Your work is truly spectacular! Is there any chance that you might offer some of your custom parts for sale to the rest of us (there are MANY) that you have created for your Famo? Especially the engine i the engine bay. What do you think?
Jim in USA
Jim in USA
Hi Jim, thanks for the Kind words, I don't think I'll be offering custom parts as that would be a whole new ball game for me. I'm happy building armortek models and adding that bit extra. It sure does go down well, and if it benefits armortek and they keep producing interesting subject matter then I'm happy .
Now a nice big Jagdtiger with a complete fighting compartment would be cool but not the one with the crappy Porsche suspension set up (do you like the way I just slipped in the Jagdtiger request?)
Kind regards Phil.
Kind regards Phil.
- This one
- jt_bw_trailer.jpg (29.19 KiB) Viewed 1887 times
- Not this
- th (6).jpg (16.32 KiB) Viewed 1887 times
The steering box and power steering ram added.
Last edited by Phil Woollard on Sat Dec 15, 2018 7:56 pm, edited 4 times in total.
Looks verry nice Phil. Funny I am doing the same parts in time and the floor from the cabine.
Motion and sound now fitted and working nicely. The steering actuator is working beautifully and I think you can see in conjunction with the steering wheel, it reacts just like the power assisted steering would, a very nice smooth and powerful operation with a realistic hydraulic pump valve lag, no not lag that's the wrong word, response... valve response.
I do like the quality of the sound file with the added track and running gear clatter (thankyou Thomas), the v12 tick over and revving engine are most convincing, along with the fan spinning away and the reduction gearbox contribution ( which to me sounds like the hydraulic pump in the distant back ground).
The twin speakers forward and aft help with the illusion, I'm a happy bunny right now! This is all uncharted territory and quite demanding and at the same time exciting!........Phil.
See video below.
See video below.
- Been liked: 19 times
Brilliant job. This has certainly proved to be another great model. Excellent work.
Nice Work Phil,
Looks real Great. I Miss yor winch, are the Akkus in this Place dir aber, or do you make another Solution?
Thanks guy's, Florian I'm still working on the winch, I may have a part that needs replacing...regards Phil.
The worn gear shaft is not true, probably not centred in the chuck during machining so it wobbles
Maybe. My gear shaft was crooked, so I ordered a new one. Now it works.
Where do you put your akku? - I will make a load box like the box from Indiana Jones 'bundeslade' ... Tke my battery inside, so I can build the tool boxes ...
I think for now the batteries can go in the tool lockers as standard but I may make an Indiana Jones box like you for the load area
You take the lead gel battery like Armortek? -
I use the LiFeP04 battery. They have more power, capacity, and longer run... In my 251 I have 10Ah and drive a hole meeting weekend without loading.
Also the weight is only 3kg. Unfortunatly they cost about 200€.
Take this one...
https://www.i-tecc.de/shop/lifepo4-batt ... adway?c=55
Take this one...
