Phils Famo build
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Re: Phils Famo build
Post by Brian Ostlind »
What a BEAST!!!
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
Hi Phil,
The beast is growing up, verry fast. 😨 looking verry nice. I have seen a little construction problem, at the front Brakes of the mudged. You can't fix 2 screws.... I show the problem and my solution later in my Building Blog...
Die you even see the problem Phil?
Has liked: 2282 times
Been liked: 7196 times
Maybe not Florian show me please, regards Phil.
I need to get the engine and gearbox out the way so I have made a start, there's along ways to go yet! You build an engine then you cut 1/3 off the crank and sump.
I've fitted a 24v motor and reduction gearbox this is centered at the crankshaft this will then run the fan, water pump and generator
I've just found a photo of a four bladed famo fan so I'm happy now!
I'm not looking forward to making the headers although with a little poetic licence I should be able to hide more of the drive motors
Last edited by Phil Woollard on Fri Nov 16, 2018 8:39 am, edited 2 times in total.
florian rudolf
Looks realy great Phil,
looking forward to see how many space you have after, installation from the speaker. Could you make me an engine dummy too?
The mudged problem... have a look at part nr.: CS0344. The back side is no matter. The front side, you but the screw into the hole, butt you can't fix the nut. I'll take a M4 and make a thread into. Bevore I fix the part CS0344 on the frame.
regards
Florian
Thanks Florian, your Famo is looking very nice indeed! Could you post a photo of the offending mud guard fixing please? This will help me and many others also :D, now I have started on the engine details it will be a while before I get to the body work again, so it's down to you now 8)
Regards Phil.
After the engine detailing then the bell housing, UJ's and gear box , then the air tanks and finally the exhaust system x2, oh and a radiator, that's all around two weeks work.
famo chassis.png (162.62 KiB) Viewed 1708 times
florian rudolf
Hi Phil,
thanks.... I'm just now on the suspension. If I am back on the bodywork I'll post some pics from my solutuion.
Been logging and general farming type stuff lately but managed to do a bit more to the engine.
A nice little Tamiya example
florian rudolf
Wow looks great Phil,
I'm not shure in time, if I make an enginedummy, but if I see that... mybe ;)
by the way, I want to build scale function winker... Do you have any pictures of the winker details? - I did'nt found any of that.
Thanks Florian, no winkers seen as yet :wink: but I will post details if I come across any, regards Phil.
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Phil
Great build and if you want winkers Tim Catton did them working for the SKDF7
I dont know if they are the same type though.
florian rudolf
Hi Derek,
I want to make them working. How it goes is not my problem, unfortunatly I do'nt know how they look like.
In my SdKfz 251 are they working too, but they look diffrent.
Thanks Derek, ref the winkers, were they flashing lights as we know them now or were they the flip up semaphore type because I have no idea ! Or are we talking about the width indicators? Regards Phil
Derek Attree
Hi Phil
On the skdf7 they were the flip out type a bit like an old Austin 7
I had a 1953 Morris minor with "flip up side cators" as Steve Coogen used to call them, basically it's an electro magnet that pulls on a simple cam that lifts the arm with a yellow illuminated marker on the end, I don't think I will install a pair on this build but it would be interesting to see one on florians build :D ….Phil.
