Phils Famo build
Has liked: 2282 times
Been liked: 7196 times
Re: Phils Famo build
Glad you guys are watching with interest, Mick you would love one of these and it's starting to get heavy!
A question for Armortek, do we need to grind a flat on the fixed end for the angle setting grub screw to sit in or will it just need nipping up tight as is?
I was a bit worried about this measurement between the torsion bar bearings as theres nothing in the Bible about it. Once you you have tapped the bearings on and locktighted the grubs and slid it in the torque tube you are stuffed.......
So all I did was assemble the torsion bar, just nipped the grubs and slid it all in and as the m6 counter sink pulled it all together the grubs held it at the correct distance......
Then just measured that distance, factor in a little clearance and set all the rest the same. Maybe a bit fussy, and no doubt the big m6 would have pulled it all in even with the locktight set but I want it just right
It's like a train to photograph
I have assembled the front end with all the expected fetling of the bushes.
It's all very nicely thought out ( I keep saying that)
Chunky brute
Chunky brute
Brian Ostlind
Has liked: 976 times
Been liked: 2068 times
Post by Brian Ostlind »
:shock: Phil that’s outstanding. You are making me feel like a turtle and I haven’t even got my kit yet!
I expect that you will catch me up Brian, I may go back to the bergepanther for a bit , I just want to get the rolling chassis done for now, regards Phil :D
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
Awesome Phil, you do not do anything else ?! - I'm not that fast ... - Fell me like an idiot ;)
Hi Florian, I'm at the gym weight training this morning, I sell our chickens eggs there to (three times a week) got a bit of looking after the land to do,a few animals to care for and some general building/maintenance as well. Other than that this time of the year i'm in the tank workshop building!
How are yours wheels coming along? Regards Phil.
florian rudolf
Hi Phil,
would you like to have this scale srews too?
https://knupfer.info/shop/index.php/deu ... -kopf.html
I don't know jet if they make this for us, but if there are some more needed than we have a good chance to get the screws. Its special for the rubber of the chain.
Finished the chassis!
All the wheels have rivets and are primed, the axles and torsion bars are complete and etched primed, I shall install this lot tomorrow.
Every thing cleaned with meths
Etch primed
Etch primed
A Tip, warm everything to be painted just like it's summer time
Locktight all the grubs and threads
The assemblies marked with white are for the left side
An example of 4mm head  and standard m3 head
Has liked: 794 times
How many elves do you have in your shop??
I hope you are not using the ones from the North Pole because in that case I can forget my Christmas present!!
Has liked: 165 times
Been liked: 849 times
Ahaa we have finally found Phils secret!! "I sell our chickens eggs there to (three times a week)" I need to get in the chicken business!!!! :mrgreen: :mrgreen: Then I could get a FAMO! Awesome! Sorry Phil couldn't resist.
I thought you were going to finish the others (V2, Berg) before starting the FAMO! :shock: I know - I have 4 models in process too.
That front end is awesome! Very cool - I'm glad you did start and give us a treat. Lovin those meaty tires. They look like earth mover tires!
B
Oh no my secrets out and it's eggs lol. You would have to sell a lot of eggs to get yourself a Famo! I do sell my honey as well but the same applies. The elves will be busy today as the weather is not good in the UK, it being cold and wet, so it's into a nice warm tank workshop for me, maybe six hours of building if I'm left in peace.
An update on my question for Armortek ref the torsion bar fixing grinding , and the answer is No you don't need to grind a flat on the fixed end, the big grub screws and the big counter sink will hold it all just fine.
Ive been thinking about the Famo sounds system, so.... there'a a big V12 banging away up front, lots of room for a speaker in that area.
There are twin exhausts which exit through the rear cross member, so lots of noise and a little smoke in that area but with little room.
My plan is to hide small speakers somewhere around the rear as far back as possible. When filming or showing I want the kinda nice Doppler effect ( i think that's how it's spelt) as the vehicle passes by. Listening to Armorteks videos there's plenty of transmission and running gear/track clatter going on, so that's great.
Should be interesting trying to sort a workable system.....Phil.
SdKfz9_FAMO_4 recovery with spade.jpg (143.24 KiB) Viewed 2691 times
Love this photo," traction issues", look at the material that the famo tracks are removing as it struggles to align the Tiger to negotiate the approaching obstacle ! I reckon i may lose the odd track block when replicating this for VT work (we will have to wait and see) but replacing them is all good fun as far as i am concerned, and will facilitate yet another photo shoot opportunity!
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Phil
Looking on in envy wont get mine till the end of the year as late to order.
But this thread is going to be very useful making mine
keep up the good work.
Derek you are going to love it!
As with all German vehicles with overlapping road wheels it's a bugger to work on, once you have worked out a system/technique of wiggling all the wheel assemblies onto the axles at the same time then your away! If you need to remove any even one then it's not going to be easy but I have a plan.
I am considering removing the 2.5mm buttons on the tandem wheel assemblies and drilling and tapping with m3 (clearance drilled for the outer wheel) I will then use m3 small head bolts fitted from the front so it stays in scale, you can then at least remove the outer wheels, and then the next layer, without the hassle of de tracking and then wiggling all the assemblies off or on at the same time. I suppose if you never intend to remove the wheels you could leave as is. You could also bond the 2.5 button from the back so you can remove just the nuts. All good fun regards Phil.
I must confess that I have put flats on the torsion bar fixed ends, over a period of time they may become loose if not done this way, this is my own mod and maybe not necessary.
Setting the angles, left and right are different i have drawn both 25 and 35 deg for reference.
It's longer than my table lift which can happily accommodate a KT
Lovely looking road wheels, they all clear each other and turn effortlessly, you may need to "chock" as it will escape off the lift if it can!
You may be wondering why has he painted those beautifully finished motors and gearboxes....
It's so when it's all together and if I fit a Maybach they will become lost to some extent and not so noticeable
interesting build, and big. i like that degree measuring tool, i will try and get one of those, regards simon manning.
