Martin's King Tiger
- Brian Ostlind
- Has liked: 976 times
- Been liked: 2068 times
- Gerhard Michel
- Has liked: 3 times
- Been liked: 691 times
Re: Martin's King Tiger
Nice to see some of Olaf's steel track links again. I also use them on three models (but not rusted artificial like these).
Gerhard
Gerhard
- Martin Hofmann
- Has liked: 151 times
- Been liked: 2014 times
Hi Brian,
hi Gerhard,
thank you for your comments.
After some electric fights with the new radio and the receiver i was finished with all components in the hull.
So i can mount the track to the king tiger the first time after 2 years of building. The tracks are steel and the rust is naturaly done with di water.
At the moment the swing arms are a little high, but that will change if the turret is on the hull and the first kilometer is gone.
hi Gerhard,
Regards Martin
- Gerhard Michel
Hi Martin,
marvellous finishing, nice innerworks! But why you didn't use LiFes for such a magnificent specimen? Less weight and floor space requirement, more power and endurance!
Gerhard
Gerhard
- Fabian Bekkers
- Has liked: 190 times
- Been liked: 120 times
- Martin Hofmann
Hi Gerhard,
hi Fabian,
thank you for the nice words.
Gerhard: the lead batteries are in - at the moment i bought the king tiger - so i didn't change it!
But first with the tracks on, a tank looks like a tank
hi Fabian,
Regards Martin
- Chang
- Has liked: 16586 times
- Been liked: 487 times
Hi Martin,
It looks good to combine the later type track with the 9-tooth sprocket wheel. Well done!
Regards,
Lerh Chang
Regards,
Lerh Chang
- Martin Hofmann
Hi Chang,
thank you for the comment. Yes i like it too.
Here are the next photos of the hull with side skirts and the barrel mechanism.
It's time to get ready for Hausen am Bach
Regards Martin
- Martin Hofmann
Here are the next photos of the progress which is coming near to the end........
Regards Martin
- Chang
Hi Martin,
Thumb-up to your KT! It is really the first class model.
I am interested in your upgrade gun elevation mechanism. Is it the customed made or new Armortek's upgrade parts? Looks so good. Any motion film can be shared?
Lerh Chang
Lerh Chang
- Martin Hofmann
Hi Lerh,
thank you for the nice words, and sorry for not answering so long time, but i was in Hausen and after very busy.
The one and only origin part was made by Armortek is the round and the cover of brass in the left side of the photo.
The angle at the right side and the spindle are modified by me and all other parts are sratched built by me.
The trick is, that the motion of the gearmotor is connected with the spindle only and the angle is the torque support.
So you can't see any out-of-roundness during the rotational movement at the barrel. It is a very even movement.
I will try to make a video and take it to youtube.
Here are some more photos of the finished Kingtiger.
Regards Martin
- Martin Hofmann
Hi Lerh,
after a long time here comes the video. Not so long, but i hope you can see what i describe before.
Regards Martin
- Chang
Very impressive Martin!
Lerh Chang
Lerh Chang
- Has liked: 165 times
- Been liked: 849 times
- Martin Hofmann
Hi Bob,
hi Lerh,
thanks for the compliments. One of the last things i have added was the "Sternantenne" because it is a Befehlspanzer.
hi Lerh,
Regards Martin
