Yves Panther A update
mark lawson
Has liked: 2519 times
Been liked: 445 times
Re: Yves Panther A update
Post by mark lawson »
Yves, Vanavond sprak ik met Lee, hij zal contact met je opnemen over de touwen
groeten uit Engeland.
RAG Militärmodellbau
IG Militärmodellbau
yves mouton
Been liked: 741 times
Post by yves mouton »
Hello Mark,
I already ask Monique for the panther cables.
Regards Yves
Has liked: 2282 times
Been liked: 7196 times
Little touches like the replacement barrel makes all the difference, adds much interest which some find hard to achieve,
Regards phil.
yves mouton
Hello,
Some more work on the panther,
Made 2 towingcables
Towinghook now finished
Made a little modefication for the track tension,
to keep the tension bolts in place.
Also started on the electronics
Regards Yves
Has liked: 746 times
Been liked: 360 times
Post by Christoffer Ahlfors »
Nice improvement for the track tensioning bolts! :D
I hate when they just fall into the hull and you have to disassemble to reach them.
Gotta try that!
Has liked: 161 times
Been liked: 847 times
I agree the track tension bracket idea is excellent. I like it better than a machined solution.
Excellent details all around - you've added a lot of extra parts! $$$$ :shock:
Great build - good to see progress!
yves mouton
Thanks for the nice comments on my build,
next few days i am gonna airbrush the wheels and put them on the swingarms,
then my build is gonna stop for a while because i have to go to the hospital
for a tennis elbow operation :(
Hopefully i can start soon back on my build.
Regards Yves
Yves
I will miss your progress posts! But wish you the best for your surgery and quick recovery!
yves mouton
Thank you Robert,
I hope i can start back after 2 weeks little by little,
i work in construction so for my work i am out for at least 3 months says the doctor.
Best regards Yves
yves mouton
Hello,
Wheels are on the shafts
I work also on the back turret hatch, servo controled, this i put tomorrow on the forum,
now my arm must rest because i got a tennis elbow,last week i was in the hospital for a operation
i workt already to mutch arm is swollen again :( :(
Best regards Yves
Take it easy Yves! Good to see you are able to make some progress!
yves mouton
Hi,
Here are the pictures of my servo controled back turret hatch.
Best regards Yves
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
Hi Yves,
That's what I like to see moving bits. Looking good.
Dennis.
yves mouton
Hello,
Thanks Dennis, its a lot of work to make the hatch work properly,
i test the hatch by hand moving the servo arm but is see that if i wanne open it the hatch tilts to the right,
so maybe i have to use a spring so that the hatch remains parallel with the back of the turret.
Best regards Yves
Dennis Jones
Has liked: 10 times
I had similar problems with opening and closing the rear doors on the 251.
Dennis.
