Radio gear advice before purchase
Covering Transmitters/ receivers, wiring schematics, requests for new options, etc
David Stewart
Has liked: 3 times
Been liked: 11 times
Post by David Stewart »
Morning all
Having read the guide on the knowledge base and other owners posts I have been looking at radio now that my motion pack is on its way. I have found a Spektrum DX7 radio with receiver (AR7100) for sale second hand at a fair price and as I am not an expert on this wanted some guidance before I commit to the purchase.
It is one of the first 2.4 systems I believe as it uses Dsm2. Does any one here use this setup or can advise if it's a good choice?
Just after some advice as not very knowledgeable in RC systems
Thanks all
Armortek 2010 Mid Tiger 1
Has liked: 1040 times
Re: Radio gear advice before purchase
David, hope you found the Knowledge Base helpful. Its easy to get lost in proprietary jargon in this field.
DSM2 is compatible with the Armortek motion pack. It’s the Spektrum proprietory anti-jam technology using spread spectrum waveforms without the later frequency hopping protection. It’s fine.
You may have a problem though with the receiver. It’s intended for RC helicopters and the specifications appear to show a required input voltage of 6-10 volts and it has built in failsafe modes, which might not be helpful. Some of the channels supply unregulated output voltages of up to 10v, which are intended for high power helicopter servos. Someone else might confirm I’ve read that correctly. The Armortek power output for the receiver is 5v/1amp and is not therefore compatible. You could probably find a replacement DSM2 compatible Rx online relatively cheaply.
Hope that helps.
David Stewart
Has liked: 3 times
Thank you Stephen I did find the knowledge base very useful.
Appreciate the advice I will keep looking
