Martin's King Tiger
- Martin Hofmann
- Has liked: 151 times
- Been liked: 2014 times
Re: Martin's King Tiger
Here comes the next photos of the turret with priming and the first layers of painting.
Regards Martin
- Marco Peter
- Has liked: 1540 times
- Been liked: 798 times
- Martin Hofmann
Hi Marco,
thank you for the nice words, but this is only the begin of a long way of painting and weathering and so on....
Here are the next photos of the turret with numbers.
Regards Martin
- Has liked: 794 times
Very nice work Martin. I don't think I have the patience that you have. Keep it up.
- Martin Hofmann
Hi Vince,
thank you for your compliments. Here comes the next photos of the hull with some weathering and rust at the exhaust pipes.
Regards Martin
- Marco Peter
Love those exhausts! Care to share how you did it?
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
- Martin Hofmann
Hi Marco,
here are some photos of the tracks and the exhaust and the procedure of making the rust for my Tiger 1.
After using the different types of pigments you have to fix it with a so called "fixer". You have to do this with several layers.
Start with the dark pigments and after this take the brighter ones.
Afterwards the end of the exhausts are painted in flat black with air brush.
Regards Martin
- Marco Peter
Excellent, I'm pretty oke creating rust myself, actually it even is loads of fun! But the fixer is most likely what created that GREAT texture, thanks!
- Martin Hofmann
But coming back to the king tiger.
Here you can see the inner room of the turret full of grenades and the first photos of the new barrel adjustment.
Regards Martin
- Has liked: 749 times
- Been liked: 360 times
- Has liked: 86 times
- Been liked: 179 times
- Martin Hofmann
Hi Chris,
you are absolut right. That's the same construction like in the Tiger1.
Hallo Rolf,
die Lagertiefe ist genau richtig, weil die Schrauben mit den Scheiben das Lager festhalten müssen - obwohl es eingeklebt ist. Hier ist die ganze axiale Kraft die das Rohr ausübt aufzunehmen.
Here are some more photos of the new design.
Hallo Rolf,
Regards Martin
- Martin Hofmann
Long time ago, since the last update, but i had some problems with the final drive.
But here are the next photos of the barrel adjustment with paint and motor.
Also new is the turret with some weathering for the first time - more to come.....
Regards Martin
- Martin Hofmann
Hi Chris,
thank you for the nice comment.
Here are the next photos of the turret with the track links on it and some light for the ammunition.
Also the turret MG is mounted on the movable part of the cannon.
Regards Martin
