Steves Panther A
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: Steves Panther A
Post by Steve Norris »
After a brief interlude building Elefants I can now get back to the Panther.
I have bought a nice 3D printed partial engine and have spent the last week or so putting it together and painting it. A full engine was not necessary as most of it cannot be seen in the Panther installation (unlike the Maybach in the Tiger 1 which is much more visible).
Another advantage of the partial engine is that it leaves room to mount the speakers in the lower hull.
The partial engine ready for installation
Tannoy speakers mounted in the lower hull
The engine in place above the speakers
The engine deck fitted showing how little of the actual engine can be seen
With one of the air filters removed more detail is visible
I still have the coolant header tanks and plumbing to add before the bay is finished.
Has liked: 161 times
Been liked: 849 times
Wow that engine looks excellent and nice placement of the speakers! Is that partial engine a kit from someone on this forum?
I'm so glad you are back on the Panther! I've missed your posts here. Best regards,
Steve Norris
Has liked: 8 times
Hi Robert
Thanks for the kind words.
The engine was bought from CG-Model shop in Germany and is made by Guenter Gaebelein who is a forum member, His web site is
Panther-tanks.de and he has a number of very useful Panther parts available.
Excellent, thanks I will look into his site. I've bought parts from him before. I bought a set of his excellent early PZ4 idlers.
mark lawson
Has liked: 2519 times
Been liked: 445 times
Post by mark lawson »
Exceptional work you have done on the Panther, the Maybach from Günter looks very nice and a great addition to the model, do the air filters have internals or is the casing solid.
RAG Militärmodellbau
IG Militärmodellbau
Steve Norris
Has liked: 8 times
Hi Mark
The filters are fully detailed on the inside and the filter element can be removed by separating the upper and lower parts of the housing.
Steve Norris
Has liked: 8 times
Mark.
Here,s a shot of the completed engine bay showing one of the air cleaners removed and separated into its component parts
It's all very red in there
Steve Norris
Has liked: 8 times
To add a bit more detail and prevent the areas under the cooling fans and vents being empty I have built up a basic set of radiators, fan mounts and airflow diverters out of plastic card. These are just basic shapes as very little of them can be seen when installed, the fans themselfs are 3D printed and are a little more visible.
The boxes during construction
Red oxide applied, the fans awaiting paint
The fans installed
The fans installed
The boxes in position
A view of the completed engine deck
Next job is the engine bay hatch
mark lawson
outstanding work Steve, the fans and air ducks add depth to the model making for a far more interesting model.
IG Militärmodellbau
mark lawson
IG Militärmodellbau
Been liked: 1768 times
lovely job steve, another level, regards simon.
Steve Norris
Has liked: 8 times
Thanks for the positive comments.
A little bit more achieved today.
Spare track hangars added and Vincent's superb steel tracks hung in position to see how things look
Has liked: 2282 times
Been liked: 7196 times
Very very nice Steve regards Phil.
Has liked: 794 times
I am really enjoying this. Keep it up.
Steve Norris
Has liked: 8 times
Finished assembly of Vincent's steel tracks and installed them, looks good!
Overall view of tracks and spares, the extra detail is a big improvement
Close up of the back end
