Andy's 25 pounder build and questions!!!
andyquirot
Been liked: 33 times
Post by andyquirot »
Hi all
I have started my 25 build I have enclosed some photos.
I have counter sunk the back of the wheels so the break drum moldings will fit closer.
I have also fitted bolts with the heads chopped off and nuts on to make them like studs.
Question (maybe for Dave at Armorpax) the molded shells from the limber do not seam to be the correct size to fit the barrel are the shells to big or is the barrel not drilled large enough.
Regards Andy Q
Primed
Primed
Started
Started
Wheel back
Wheel back
Wheel front
Wheel front
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Re: Andy's 25 pounder build and questions!!!
Hi Andy,
Hopefully my Shells are about the right size! None of the rounds we have made fully fit the breeches on the various guns without some mods. I have left the brass insert out on the 17 Pdr Pheasant so I will hopefully be able to get a round in.
Dave
www.armorpax.net
Hi Andy,
Also noticed you had the good sense to fit the inner trail tie downs early on. I like and idiot left them till I'd all most finished the Pheasant carriage and then remembered what a pain they had been to drill on the 25 Pdr after it was assembled...................you'd think I would have learned by now how to put these things together :-)
Dave
www.armorpax.net
andyquirot
Hi Dave
Only because of all the photos that you sent me. Thanks
I you look at the limber in the background you will see that we all make mistakes I have fitted the door retainers wrong but they are all fixed now so they will stay like that.
Regards Andy Q
andyquirot
Some more photos for you all.
Regards Andy Q
andyquirot
More progress on the building.
Regards Andy Q
