Famo 18 tonner.
- Been liked: 3566 times
Re: Famo 18 tonner.
Probably abut time we post some more details on the 1/6th scale Famo project.
We will start the design process in a couple of months time. This will, as usual, involve desk top research as well as measuring up of a real vehicle followed by prototyping. We anticipate a launch in the summer of `18 - more precise dates will be set once the design is reaching the end and we have an idea of production scheduling.
The variant that we intend to make is the one in Timo's pictures in the previous post.
I have had several mails with regards to the design - unfortunately we cannot crowd source the design of the model as almost everyone has a different wish list. However, one common request has been to keep the engine bay empty for people to add an engine. We should be able to do this, but at this stage ... without even starting the design .. we cannot tell for sure. Apart from the need to locate the electronics somewhere, we also need to make sure there is enough weight over the front axle to ensure that the vehicle can steer without chronic under-steer.
Kian
Kian
- Has liked: 2272 times
- Been liked: 7154 times
Re: Famo 18 tonner.
Sounds great boss!
Now I have two words to say and that's "Ballast", now I am aware that's only one word but I thought that it was so important it was worth mentioning twice. We can always add ballast to the engine bay like strips of lead or a battery if we need to?
Regards Phil.
Regards Phil.
- Has liked: 7 times
- Been liked: 46 times
Re: Famo 18 tonner.
For me, an empty engine bay is not important. If for dioramas etc the engine is wanted on display, then simply remove the batteries or electric motor that might be in there and replace with a dummy scale unit. Much more important is how the model runs and handles with prototypical operation and suspension.
- Has liked: 10 times
- Been liked: 224 times
Re: Famo 18 tonner.
I assume like SDKFZ7 each tack will be driven individually by a motor which will make steering a bit easier. If that is the case perhaps someone could come up with a clever way of mixing the steering front wheels with controlling the tracks. It sounds easy but normal mixing is ok going forwards but when you go in to reverse the front wheels go in the opposite direction you want the vehicle to go. I speak from experience of controlling the SDKFZ7.
Dennis.
Dennis.
- Been liked: 3 times
Re: Famo 18 tonner.
Hi all,
my thought concerning the power unit is, a single motor would be cheaper than a twin version. But whatabout steering with a single motor, steering controlled only with the frontaxle and pulling maybe the Sd Anh.116 with a Panzer III loaded for example? I am not sure, if the steering over the frontaxle will collapse in this case. The reliability to manage this system is higher with a twin motor version I think.
Regards Dietrich
Regards Dietrich
- Has liked: 197 times
- Been liked: 737 times
Re: Famo 18 tonner.
As we are going to have the towing version/late example of the glorious Famo, is there any chance that Armortek would consider provision for the spade mounting points attached to the very rear of the chassis. They are simple lugs welded to the ladder chassis rails and would add interest to the rear of the vehicle whether they were to be used or not. Most late versions seem to have this as a standard fitting.
Another question ( please note that I would not expect a direct answer to these questions
) How about a small additional kit comprising of the spade and associated fittings, it's all good business!
Regards Phil.
Regards Phil.
- Famo spade .jpg (45.93 KiB) Viewed 9019 times
- Famo parking up guide.jpg (11.86 KiB) Viewed 9019 times
- Has liked: 1034 times
Re: Famo 18 tonner.
For that small but very distinguished group of truck fanciers, a Christmas puzzle:
Cheers.
Cheers.
- Been liked: 19 times
Re: Famo 18 tonner.
I like the nose of the Tatra afterwar diesel prototype, it looks so "fast"
Christian
Christian
Re: Famo 18 tonner.
That Tatra v12 completely filled the engine bay, I don't want to reproduce that any time soon!
- Chang
- Has liked: 16249 times
- Been liked: 474 times
Re: Famo 18 tonner.
Just for fun. Found another rare "FAMO" photo (or is it?) https://www.pinterest.com.au/pin/701224604453151083/
Guess it was a post-war built one. It does not look as big as a 18 tonnes FAMO, maybe a post-war built 8 tonnes Sd Kfz 7, or 12 tonnes Sd Kfz 8?
- Has liked: 99 times
- Been liked: 446 times
Re: Famo 18 tonner.
For those contemplating doing an engine bay for one of these.... wow!
RPR
Re: Famo 18 tonner.
Update on the Famo ...
Now that the Rolls Royce is in full production, the current plan is to measure and photograph the Famo in the last week of Feb/ first week March. Once that is done, design work will start in earnest and should be able to provide more details on the provisional ship times by end March or early April.
Kian
Kian
- Chang
Re: Famo 18 tonner.
The BIG FAMO ball is rolling ~~~~~
Re: Famo 18 tonner.
One or two questions ref the forthcoming Famo spec, will the towing example have a winch? will the towing example have the spade ? Will it have the good looking larger balloon front tyres? Will the tracks have the rubber pads? Will it have the canvases? Regards Phil.
