armortek option pack wire extensions?
- Been liked: 48 times
Hi everyone, While working on one of my builds I see that the wires that connect the recoil unit to the amp unit are difficult to to plug / unplug when removing the turret due to the internal layout. I was wondering if there was an extension type cord that has a male on one end and a female on the other? This way I can leave the two wires plugged into the amplifier unit and have all the connections / disconnections at an easier location.
- Has liked: 1475 times
- Been liked: 1674 times
Re: armortek option pack wire extensions?
Something like this ?
http://www.armortek.co.uk/Forum3b/viewt ... f=4&t=5756
But without the second leg.
For the connectors you need to look on newark.com for Molex plugs and sockets.
Or if you can get hold of just the pins, you could reuse the housings and split the recoil module leads.
Then you could use standard Futaba male/female servo connectors for the disconnection point.
Yes! just like that. do you have a link where I can find the female plugs as a standard futaba female plug should fit the amp's male pins?
