Steves Panther A
- Has liked: 219 times
- Been liked: 200 times
Re: Steves Panther A
Hi Steve
Your doing a great job on the Panther A brings back memories
of doing my Panther G back in the day I still regret selling her some times.
Kent Great photos thanks for posting.
- Has liked: 1040 times
Hi, Steve, just echoing what Simon and Derek are saying, great to see another build thread on the Forum, especially as interesting as yours. One day, your model will sit alongside its original.... now there's a photo! I'd like to do that with my Cent but Australia is a long way.....
Keep it coming.
Keep it coming.
- Has liked: 8 times
- Been liked: 701 times
Derek, Stephen
Thanks for the replies, Armortek have done a good job with the Panther and it's one of my favourite kits.
Stephen, it's a good point you made about getting it with the original, you never know one day it may happen.
Not much to report today.
I have spent the last 2 days putting the tracks together and this evening getting the black crap of my hands
I have also finished the Zim on the bins and these are now ready for some paint.
- Paul Wills
- Has liked: 646 times
- Been liked: 143 times
Hi Steve,
I hope you are well mate, I love tuning in to see your build progress.
its been a while since I last looked in and its coming alone nicely.
One question, how did you achieve the flame cut overlapped joints?
Paul.
Paul.
Hi Paul
Hope you are well, it's a long time since we had a North West tank meet.
The flame cut effect was achieved using a small drum shaped grinding bit in my Dremmel and just dragging it across the area you want the flame cut multiple times. Some ares had to be filled before I could do the effect and for this I used Araldite steel adhesive.
A simple mod for Panther builders that may prevent a suspension jam.
ps. not sure why the second photo is upside down, it's OK if you click on it
Tracks on for the first time
On thing I did notice when adding the wheels was that they had a wobble on the axle, Yves also noted the same problem. Hopefully an easy fix will be to add a thin shim washer behind each wheel which should take up the unwanted end float on the axles.
More to follow
More to follow
- Been liked: 741 times
Hello Steve,
Nice work you done on the panther.
Ps: i bolt my inner wheels together, for the outer wheels i try to use a shim like you say.
Best regards Yves
Best regards Yves
Armoured schnorkel cover next
The intake schnorkel will be added later hopefully
Hi Steve, have I missed something regarding the lovely exhaust brackets? They look the business ...regards Phil.
Looks good Steve, the kit exhausts are a little heavy, I have to make longer ones for the Bergepanther so I will not use them for that build.Regards Phil.
- Has liked: 6 times
- Been liked: 194 times
Hi Steve,
Nice progress well done.
You can keep the kit pipes just take the thickness down with a Dremel or make a new ends as I did with
the excellent aftermarket exhaust pipes with cast guards Bob M once made.
Not that hard to make, here is how I did it:
(scroll down to last 1/4 of the page)
http://www.armortek.co.uk/Forum3b/viewt ... &start=120
It´s all in the details!
