torsion bar end caps
nick pannell
Post by nick pannell »
HI guys'
A while ago one of you put a good scale drawing of the Torsion bar end cap that is seen on the opposite side of the hull to the track wheel that it supports I need to mould some for my panther and can't find the picture can you help me please ???
Nick P. :D
Steve Norris
Has liked: 8 times
Been liked: 701 times
Re: torsion bar end caps
Post by Steve Norris »
Hi Nick.
The torsion bar end caps can be purchased from guenter.gaebelein@panther-tanks.de (CG-Model shop)
I cast some myself for one of my Panther G,s but found that there was limited space between the castings and the backs of the swing arms due to their thickness. Guenter,s laser cut end caps are a much better solution as they are a lot thinner.
Hope this is of help
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Hi Nick,
It was I who posted it in my Panther saga many mons ago:
(scroll down a bit)
http://www.armortek.co.uk/Forum3b/viewt ... &start=150
I think you might find some other things in the saga useful as well.
It´s all in the details!
William Gardeniers
Has liked: 46 times
Been liked: 282 times
Post by William Gardeniers »
Hi Nick i used Günthers excelent end caps on my Bergepanther.
With Regards William
nick pannell
Hi Guys,
Thank you for your help in this matter I can machine a mould and cast some caps out of steel putty.
regards nick p. :D
