A 47 years old love
davidwilkins
Been liked: 213 times
Re: A 47 years old love
Post by davidwilkins »
Frank,
Stunning detailed work.
Frank Breitenbach
Has liked: 54 times
Been liked: 689 times
Post by Frank Breitenbach »
Hello
Many thanks for your kind words.
Now the hook
Hello Stephen your report was very helpfull!
Frank
Has liked: 1038 times
Glad to help Frank, you're creating a masterpiece. Let me know if you need any photos or plans/diagrammes, I may be able to help.
Alles gut.
Frank Breitenbach
Has liked: 54 times
Hello
The deflector shield is now ready.
I like to build the motor compartment wiht the engine. From the engine I have a 1:25 model and many pictures but nothing from the blank compartment (I hope I use the right words). Does anybody can help me with some pictures from the compartment without the engine? This would be very helpfull.
Stephen many thanks for your offer (I write you a PM)
Frank
Last edited by Frank Breitenbach on Sun Dec 04, 2016 3:56 pm, edited 1 time in total.
Frank
Hope these help:
Frank Breitenbach
Has liked: 54 times
Hello Stephen
Many thanks for the pictures. Now I know more details. Can you provide an additional picture form an empty motor comartment. Actually I can not understand the design of thr bulkhead between the engine house and the gearbox.
Frank
Fabrice Le Roux
Been liked: 14 times
Post by Fabrice Le Roux »
Hi Frank,
Just spent a few minutes catching up with your thread. Fantastic work!
Apologies for not being more supportive, but I have been unwell so have not been able to do much modelling since Easter.
There is a fairly new product which may save you time cleaning up your 3D prints.
https://www.smooth-on.com/product-line/xtc-3d/
I have seen prints coated with this resin and it does work. You can easily add a more realistic cast texture with a light over spray of Rust-Oleum Cast Iron texture paint.
https://www.amazon.co.uk/Rust-Oleum-Nat ... B00JQ2OQ2G
This available at most large DIY stores in the UK.
Once cured the XTC-3D could also be lightly worked with a Dremel for a rougher effect.
The resin will slightly alter the dimensions of the parts but more evenly than say an automotive spray filler.
Hope this helps, and keep up the good work!
cheers, Fabrice
Frank, try these:
Frank, I haven't any photos of the engine and transmission compartments empty but this link below takes you to a .pdf file of the restoration of Australian Cent ARN 169065 with some low res pictures which might help:
http://www.paratus.org.au/single-post/2 ... update-one
Frank Breitenbach
Has liked: 54 times
Hello
Fabrice: A very interesting spray. The layer thickness that I use is 0.09mm. So mostly it is o.k. for the rest I use sandpaper.
Stephen: Yesterday I study your photos. I think now I have an idea what I have to do. May thanks for your information and in advance for your PM.
Frank
Frank Breitenbach
Has liked: 54 times
Hello
Now some details of the rear.
Frank
Beautifully done, Frank. Will you do the cooling louvres? I have some photos if you need them. Stephen
Frank Breitenbach
Has liked: 54 times
Hello Stephen
I will not to be ignorant but I try a 3D construction and it is ready. If you have photos from the louvres under the gear covers thats great.
First parts.
Frank
Frank, these are the set of louvres/cooling baffles under the rearmost part of the hull. Note the differences:
These are the baffles under the gearbox covers ie those which sit on top of the radiators:
Inside the hull rear:
Hope that helps. I like the printed parts, so much easier than making them by hand. It took me far too long.
Frank Breitenbach
Has liked: 54 times
Hello
Three louvres are mounted provisional. The fourth must wait until I know how I can lay the wires.
Frank
