First Quad's arrive with customers
Russ Clark
Re: First Quad's arrive with customers
Post by Russ Clark »
WALTER
ANY PHOTOS WOULD LOVE TO SEE IT AT THIS STAG.
Ian Rodney
Been liked: 53 times
Post by Ian Rodney »
Hey Mark,
Charlie is not as tired looking as his mats will be after coming back from Cairo night spots?
Cheers Ian
Russ Clark
You need another charlie
Walter Mackinnon
Has liked: 8 times
Been liked: 4 times
Post by Walter Mackinnon »
Has any builders reached page 9 yet .Front axel , assembled it but the drive shafts were very tight in the diff and could only turn the front steering by a small amount.
Have now stripped it all down, any thoughts would be appreciated .
Walter. :?:
Walter Mackinnon
Has liked: 8 times
Been liked: 4 times
:D
The smaller parts will be done with a air brush.
Hi all.
Decided to clean and etch prime the body work as it was a nice day.
michael hilton
Has liked: 1566 times
Been liked: 836 times
Post by michael hilton »
Hello Walter, you are well on the way with your build, watching with interest. It is useful to follow a build....irons out any unforeseen problems.....best wishes.....Mick
Walter Mackinnon
Has liked: 8 times
Been liked: 4 times
Hi all
Done well to day. Now time for a rest, tomorrow is another day.
Regards Walter.
Made good progress today.
Went together very easily.
Fingers sore from the small nuts.
Phil Crowther
Been liked: 10 times
Re: First Quad's arrive with customersft
Post by Phil Crowther »
Walter Mackinnon wrote:Has any builders reached page 9 yet .Front axel , assembled it but the drive shafts were very tight in the diff and could only turn the front steering by a small amount.
Walter. :?:
I have had the same problem with the front axle. Both drive shafts were as tight as the proverbial duck's bottom to the point that they would not move freely. The longer drive shaft, Drive Shaft D, seems to be too long as, with the drive spring fitted in the diff, it proved impossible to seat the Pivot Pins in their respective holes!
Am I missing something obvious?
Can anyone offer a tip as to how I can get this front axle working freely and smoothly? :?
Has liked: 1484 times
Been liked: 1693 times
I haven't had my hands on a Quad yet but from experience with tank wheels, I would check that the inner bearings in the stub axles are fully seated. If they're not fully seated, that will have the effect of reducing the clearance available for the drive axle.
Walter Mackinnon
Has liked: 8 times
Been liked: 4 times
Hi Phil.
Did you read the post from ARMORTEK the drawing on page9 is not right the diff shoud face the other way round. Walter
Phil Crowther
Hi Walter and Adrian,
Thanks for the info. I was a bit suspicious of the diff but it didn't look as if it would make a difference.
Oh well, time to strip down, check the bearings and swap the diff around......
Watch this space! Phil
Phil Crowther
Well that didn't work. No matter which way round I put the diff, the drive shafts seem to be too long! The only way I can get the pivot pins in place is to leave out the two springs but then the drive shafts jam when steering.
I am assuming that both the differentials supplied are identical? I am at a loss and need help or maybe therapy.
Pictures please....
William Gardeniers
Has liked: 46 times
Been liked: 282 times
Post by William Gardeniers »
Number 14 arrived in Holland nice part's, now priming with temperatures above 15 and in the winter building.
Regards William
With Regards William
chris fry
Been liked: 525 times
Post by chris fry »
Hello Phil,
Make sure the 2 drive shafts fit all the way in to the diff cups and in to EM0211 stub shaft, check the pins on either of the 2 shafts can slide freely in the slots on the cups and stub shaft, Might need a dremmel with a ball end just to debur the inside of these cups allowing the shafts to move freely and a flat file to open up the slots, If the shafts are to tight with the springs EM0515 in place leave them out, The shafts are never going to fall out,
The diff and pinion are a match set so don't mix them up, Keep them separate.
If you have painted the front axle remove the paint were the stub axle fits on to the axle, they are a nice fit without paint so make sure the stub axle can move freely left to right,
Any other help needed just shout.
chris.
