Has anyone used JB Weld's SteelStik epoxy putty ?
I need to glue some aluminium sheet parts together at right angles and can't use the normal epoxy glue as it will pool too much.
I've not been particularly impressed with how well Milliput actually adheres, so thought this might be an alternative.
JB Weld SteelStik
- Has liked: 1475 times
- Been liked: 1674 times
- Has liked: 60 times
- Been liked: 33 times
Re: JB Weld SteelStik
I've used all of JB Welds products and have to say the results have been a bit hit and miss and certainly don't live up to all the claims made for their stuff- eg repairing engine blocks and the like. As far as modelling is concerned I personally would not like to rely on it for structural pieces. If you have already bought Steelstik I would be tempted to use it on one joint and test the strength afterwards. The other thing is (according to a wholesaler I spoke to) JB Welds stuff can lie around in warehouses for a long time. Cant remember if Steelstik has Use By dates but something to bear in mind.
Thanks Peter.
I've ordered one stick so will see whether it has an expiry date and whether it will be sticky enough for what I need.
