My 251 build.
Forum for discussion relating to the Sdkfz 251
Tom Wittstock
Been liked: 18 times
Re: My 251 build.
Post by Tom Wittstock »
Hello Dennis, I also have the 251 but have not started it yet. I have a question for you, what method are you using to install the rivets? The rivet snap tool? or something else... :shock:
Any pictures will also help....
Thanks Dennis...
Dennis Jones
Has liked: 10 times
Been liked: 230 times
Re: My 251 build.
Post by Dennis Jones »
Hi Tom,
All I have done is made up a brass former as per photo using a 4mm drill just deep enough to leave the shoulder of the rivet just proud of the surface and then rivetted the rivet flat on the other side. A note of caution when you are ready to start rivetting make sure you do it in the right order as you want to be able to get the ball peen hammer in there to rivet. You will have to cut the rivets down in length and you will have to experiment to get that right, I use a pair of heavy side cutters. The dummy rivets of which there are only a few as they only go through one layer will need to be shorter.
Make sure you put the plates that hold the visors on goes on with the counter sink on the outside.
Also I have attached a photo of the track rod position underneath not on top as shown on the plan as it fouls the tierods if put on top.
Hope will be of some help.
Dennis.
Tom Wittstock
Re: My 251 build.
Thanks Dennis, pictures are a thousands words.... :D
Dennis Jones
Has liked: 10 times
Re: My 251 build.
A few more photos of the build so far. Hoping to open and close the sides and rear doors by radio.
Dennis.
martin pitcairn
Has liked: 799 times
Been liked: 8 times
Re: My 251 build.
Post by martin pitcairn »
Looking very good, well done! I love this version, if I had one of these it would either be the Flack or the engineer version (my other favourite)
Martin
Dennis Jones
Has liked: 10 times
Re: My 251 build.
Deleted this post.
Dennis.
Dennis Jones
Has liked: 10 times
Re: My 251 build.
A bit more progress. Have now transferred video to Utube and it is better.
Dennis.
bryanrmassie
Has liked: 7 times
Been liked: 17 times
Re: My 251 build.
Post by bryanrmassie »
Hi Dennis
That is brilliant, wish I had your knowledge, cant wait to see the finished article.
Bryan.
Re: My 251 build.
that looks good dennis, nicely done, regards simon.
Has liked: 166 times
Been liked: 849 times
Re: My 251 build.
Dennis,
Your 251 is looking awesome! Very smooth motion on gun rotation and elevation. Will be a very unique model. Really enjoy all of your projects.
Dennis Jones
Has liked: 10 times
Re: My 251 build.
Thanks Robert and to all other comments. Just starting on the opening and closing mechanism for sides and rear doors, watch this space.
Dennis.
Ray Brown
Has liked: 26 times
Been liked: 103 times
Re: My 251 build.
Post by Ray Brown »
chuck norris approves.gif (1.49 MiB) Viewed 5491 times
Dennis Jones
Has liked: 10 times
Re: My 251 build.
First photo shows method of rotating gun platform, a bit rough but it does the job. Just a standard servo but I cut the top off the shaft that turns the pot from the final drive and also the limit lugs. This means that the servo will stay in the position driven to even when stick is returned to center. Gears are from my R/C racing car days. Cable go to elevation servo and led in barrel.
Second photo, I want to fit super bright led in end of barrel and I couldn't drill the barrel for the cables as too long and thin. So I cut a slot with the Dremel and disc and used car body filler P38 to cover up the slot.
Dennis.
jseverett
Been liked: 3 times
Re: My 251 build.
Post by jseverett »
Dennis,
Where did you acquire the Flak 38, or did you scratch build it?
Tim Semas
Been liked: 1 time
Re: My 251 build.
Post by Tim Semas »
Looking good Dennis, smart thinking.
