New radiators for tiger1
Ivano Costantini
Been liked: 735 times
Post by Ivano Costantini »
I would like to say thank you to all my friends at the forum,who showed me their support with a lot of messages and convinced me to continue my work. I also thank those who have already bought the kit in confidence.
I would like to describe to you the radiators in a more detailed way that i realized for my Tiger1. Firstly,the philosophy and the execution of construction are completely different from other reproductions on the market. I reproduced the empy radiators, to create with the motors a real air ciculation wihch also useful for cooling any eletronic devie placed behind them. All measures, with necessary adjustemnts,have been taken from the site " INFO tiger 1".
To reach a maximuna fidelity, the designs have meed with a graphic program and the master were printed with 3D printer. There were created silione molds and then we moved to the clonig of the resim master.The surfae of the conveyor is a deliberately corrugated imitation of the real fuses of materials. They used real bolts in various sizes and the engines that can operate at 24V, 12V or 6V. The installation is very simple: small changes can be necessary depending on how you built the tank, there must be drilled holes for the bolts and sleeves and part are glued.
Prior to the radiators, each modeller can apply a net or a grid acording to their preference. I made the frames in " plastic card" and cut out real mini radiators.
I hope you like.
For information:ivano.costantini@alice.it
