I have always posted photos from my pc without to much difficulty but was wondering if it was possible to do the same using iPad. The reason I ask is that my pc is now a bit of a relic and hardly ever gets used, virtually everything I do online is now with the iPad.
Using iPad
- Has liked: 8 times
- Been liked: 701 times
- Been liked: 2 times
Re: Using iPad
It's really easy on iPad.Just click on upload attachment bottom left corner of your post.I just upload from my normal picture gallery
- Has liked: 1038 times
Re: Using iPad
Steve - no reason why not. I use it all the time.
1. Open Photobucket.
2. In Upload, select Choose Photos and Videos. Navigate to your photos and select. (They will probably be in either Camera Roll or Photo Stream).
3. Copy the link to the photo in Photobucket
4. Open Armortek Forum in a new screen in Safari and paste into the posting as usual.
There is also a way of uploading direct from a mobile or tablet to Photobucket.
2. Select Settings (click on the small head icon on the menu bar, select Settings from the drop down menu).
3. In Settings, select Mobile. You'll see instructions, including an address and pin, for uploading.
I don't use the last bit much as it requires an email and attachments. I find it just as easy to upload from within PB as in the first section above.
I'm sure there are lots of other clever bits others have come across.
