How many times have you connected all the wires & leads and have had to disconnect them for whatever reason and then re-connect everything. I've decided to try this..................... Each module has has letter with each position numbered. Each lead/connection has a corresponding letter/number. Therefore, match letter/number = straight away no frustration. Works great.
Connections
- Steen Vøler
- Has liked: 62 times
- Been liked: 500 times
Re: Connections
Hi Ray
yes it's a great way to secure the reassembling after an overhaul.
I did the same thing on my jagdpanther
cheers
Steen
Steen
- Has liked: 264 times
- Been liked: 195 times
Re: Connections
I see the Mk IV motion packs are finally shipping! Is it an easy install? I've been holding off on building mine so I could install early on.
Cool!
Cool!
- Has liked: 26 times
- Been liked: 103 times
Re: Connections
The motor installation was a bit finicky but okay. Ensure you put the motor mounts on before securing the armour plates.
Ray
Ray
