TIGER 1 SUSPENSION UPGRADE
- Been liked: 2 times
I have recently acquired a second hand Armortek Tiger 1 (2007 edition) from a friend and notice that the suspension Is a little weak , the original was quite damage and very out of alignment , so after a few review with people and friend who have these type of tank I decided to go ahead and re-do the suspension with the suspension upgrade kit provided by Armortek.
So here it is , just got it through UPS today , unpacked it and ready to go at it. Quite a job at first hand by the look of it but hope to go smooth if not I may have to ask for your help.
Thanks anyway ,
JIMBO
JIMBO
CCAD
CLUB CHAMPLAIN ARMOR DIV
CCAD
- Has liked: 6 times
- Been liked: 812 times
Re: TIGER 1 SUSPENSION UPGRADE
Interesting to see how you get on with this project. I have 2 2007 Tigers. Does the kit come with suspension arms and axles?
Yes John, The kit comes basically with every thing with new harms and rods that have been flatten at both end. News screws and mounting bars,and fixed ends.
I can tell that this mod will do the job, much stronger then the original.
JIMBO
JIMBO
JIMBO
CCAD
CCAD
- Been liked: 1 time
HELLO JEAN !!
I HAVE THE UPGRADE FOR THE TIGER 1. I AM HAVING A DIFFICULT TIME FOLLOWING SOME OF THE INSTRUCTIONS.....HOPE YOU CAN HELP ME. HOW IS THE SUSPENSION BAR THAT HOLDS THE BUSHINGS ATTACHED TO THE SIDE PLATES ? ARE THE SUSPENSION BARS YOU HAVE DRILLED WITH HOLES THAT MATCH THOSE ON THE SIDE PLATES ??? MINE DO NOT AND I HAVE NO IDEA HOW THE FLOOR PLATE THAT IS ATTACHED TO THE SUSPENSION BARS CAN BE HELD IN PLACE.
ANY HELP WILL BE APPRECIATED !!
ED EARP, JR.
edearpjr@austin.rr.com
830-990-8099
Fredericksburg, Texas 78624
BUSHINGS
ED EARP, JR.
830-990-8099
BUSHINGS
Hello Edward,
The suspensions bars have drilled/tapped holes in them at the bottom and side of it, basically the same as the old one you're taken off . All the holes matches those of the side plates and the floor plate. If you don't have any hole than it must be an error on the suspensions bar.
What production year is your Tiger ? Can you provide a picture of these bars ?
Get back to me .
I completed my upgrade and it just work fine.
Get back to me .
JIMBO
CCAD
CCAD
HELLO JEAN !!
MARK MADE A VERY SLIGHT CHANGE TO THE WORDING OF THE INSTRUCTIONS AND EVERYTHING CLICKED INTO PLACE !!! PROBLEM SOLVED WITH THE SUSPENSION BAR. I THANK YOU FOR GETTING BACK WITH ME. IT'S 30 DEGREES (F) HERE RIGHT NOW AND I'VE HAD ALL THE COLD WEATHER I WANT FOR THIS YEAR !!! I HATE TO THINK HOW COLD IT IS WHERE YOU ARE !!
WHILE WORKING FOR BECHTEL I SPENT SOME TIME AT JOB SITE AT FORT MCMURDO....MERCY !!
HOW ABOUT SOME PHOTOS OF YOUR TIGER ? ALL THE BEST, ED
Hello Ed,
Glad things worked out for you. Yes you are Lucky the weather is in the 30+ here we are in the - 30 right now but spring is coming.I hope ????
Yes enventually I will get somes pictures done.
JIMBO
CCAD
CCAD
