I have a early issue Panther with the 4QD speed control set up and power supply boxes, Can anyone tell me how to wire up the headlamp and tail lamp so that it can be controled via a spare radio channel.
Lighting wiring
- Has liked: 8 times
- Been liked: 701 times
- Has liked: 60 times
- Been liked: 33 times
Re: Lighting wiring
Steve a very simple solution is to use a Turnigy rc on off switch available on tinternet for about a fiver. Very easy to use and never had one fail. Operates from a switched channel on the transmitter which are not normally used anyway.
Re: Lighting wiring
Ray,Peter
Thanks for the reply, will look into getting the turnigy switch as that seems to be a nice simple solution.
