JagdPanther - new look
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
hi all
Decided to take my JagdPanther for another travel 8)
Going to make the outside overhaul also - during the fall I made the internal overhaul and was quite happy with it, so being in the overhaul mode, now is the time for the outside parts
First I removed the old weldings - grinded the aluminium parts so it should look like a sttel cut and added Mr. Putty around it
Next is to make the surface on the fighting room more "steel" look alike by adding some structure padding
pictures will come
cheers
Steen
Has liked: 1040 times
Re: JagdPanther - new look
Looking good Steen. By the way, what happened to your hull MG? It looks as thought it's designed to fire around corners......
Steen Vøler
Has liked: 62 times
Hi Stephen
haha - yep that's right, its the newest in gun development :D
Well - case is that the part is detachable and I simply just haven't put it into place yet
cheers
Steen
cheers
Steen
Steen Vøler
Has liked: 62 times
all the Work with the welding is now finished. Also the top of the fighting compartment have been grinded with sandpaper to get it 100% correct alligned to the front glacis. Earlier it stood up appx 2 mm.
The tank is now primed in basic color Red-Brown and Next step is to build up the color scheme layer to layer
cheers
steen
cheers
Steen
Steen Vøler
Has liked: 62 times
Periscope is now drilled out and ready for installation of the inside parts
cheers
Steen
Stephen Mason
Been liked: 4 times
Post by Stephen Mason »
It is coming along nicely Steen and yet another scale detail added to the tank.
I am looking forward to seeing the finished result :wink: .
Steen Vøler
Has liked: 62 times
now the 3 layer cammo is sprayed and the next part is to spray with a lighter tone followed by weathering
cheers
Steen
Steen Vøler
Has liked: 62 times
hi all
finished the project and the jagdpanther is now painted and weathered as well as the suspension is adjusted with now torsionbars on the front 2 roadwheels on each side
cheers
Steen
William Gardeniers
Has liked: 46 times
Been liked: 282 times
Post by William Gardeniers »
Looking good Steen always nice too see a Jagdpanther.
Regards William
With Regards William
Has liked: 166 times
Been liked: 849 times
Steen,
Excellent makeover. Really nice paint. I'm jealous - would love to have a JP.
