Benedini rotary encoder
Chris glover
Been liked: 2 times
Post by Chris glover »
Hi
I have just fitted the rotary encoder to my Futuba 7c.Can somebody explain in idiot terms how to assign the sounds to the encoder.Is it a simple case of just changing assigned switches on the handset.....or do I have to reprogram the sound module?
Totally new to this so scratching my head :oops:
Ad Wouterse
Been liked: 2 times
Re: Benedini rotary encoder
Post by Ad Wouterse »
Hi Chris,
If the soundcard was initially set for another type of encoding(e.g.toggle switch)you need to reprogram it.
You can find the English manual over here: http://www.benedini.de/TBS5E_5.pdf
Good luck !
Ad
Chris glover
Been liked: 2 times
Ad Wouterse wrote:Hi Chris,
Good luck !
Hmmm, It seems that the switch isn't being seen.More investigation required!.....Amazing how the hours fly bye when scratching ones head
Tim Page
Has liked: 40 times
Been liked: 471 times
Post by Tim Page »
Hi Chris, I have just been fitting the same into my DX7.
I ended up plugging a servo into the RX to ensure that the switch was in fact working.
Each of the 12 positions on the rotary should move the servo to a different position.
This at least told me that the switch was working.
Hope this helps.
Ad Wouterse
Been liked: 2 times
Hi guys,
Tim is right, the encoder should be connected to a fully proportional channel in your radio.
Ad
Chris glover
Been liked: 2 times
Hi Chaps
Fitted a servo to test the encoder.The encoder jerks at each position,almost as if it's getting a signal to go in both directions at the same time. Any ideas?
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
Hi Chris,
Normally to test it I hold the switch in the activate position and rotate the selector knob and the servo should advance one position at a time. I assume you tested the channel with a servo connected before you fitted the encoder, I also assume this is a proportional channel you are fitting the encoder to. It maybe an idea to reconnect the pot back up to test the channel is ok. Also make sure the 3 connections from the encoder are in the right positions on the leads that came off the pot.
Dennis.
Has liked: 1475 times
Been liked: 1674 times
Did you follow the instructions provided here:
http://www.armortek.co.uk/Forum3b/viewt ... f=2&t=1716
If the servo is twitching, it sounds as though you're almost there.
It does sound to me as though the three connections from the encoder to the transmitter are wrong somehow.
Chris glover
Been liked: 2 times
Adrian Harris wrote:Did you follow the instructions provided here:
Yes followed Micks instructions to the letter
God knows what's wrong with it!
Think it may be off to visit Thomas after Christmas
Any chance of a photo of your installation ?
Chris glover
Been liked: 2 times
Adrian Harris wrote:Any chance of a photo of your installation ?
If you pm me your e mail I will gladly send you a picture.I haven't looked into adding pictures on here yet.
Done :)
Adrian
Chris glover
Been liked: 2 times
Sent :D
I've sent you an email with a couple of things to check.
Let us know how you get on.
Chris glover
Been liked: 2 times
Adrian Harris wrote:I've sent you an email with a couple of things to check.
Cracked it first time!.It was the bridges,they should be closed.I mailed Thomas and he said they should be open! :roll: .
Never mind, happy now :D
Thanks Adrian and all those who contributed,much appreciated!
