Hi Ian
Please do send me your Lincoln Mark IV photos. I will be happy to put them onto Photobucket in an Album. The more information that is available the better, particularly as there are relatively few Tanks to be looking at. My brother lives in Rye, so may be at Christmas a trip to Ashford would provide something to compliment yours of FLIRT II as is also a female tank.
On another note, I have sussed getting nuts onto hidden/hard to get at bolts. Use a suitably bent bicycle spoke, push it through the hole, then thread the nut onto it, then slowly withdraw it leaving the bolt held in place against the hole with your finger tip. Next, simply screw the now aligned nut and bolt together. Voila!
![PB230130.JPG (1.91 MiB) Viewed 3833 times Round Headed, no slot 5BA Brass Bolts](./download/file.php?id=5479&t=1)
- Round Headed, no slot 5BA Brass Bolts
Also in the photo is my steel 'podger' which is proving a Godsend in getting plates and fittings to line up so bolts go through.
![PB230132.JPG (1.76 MiB) Viewed 3833 times Indistinguishable? very little difference?](./download/file.php?id=5480&t=1)
- Indistinguishable? very little difference?
Derek Atree put me onto the brass bolts- from EKP Supplies - and although they stand only slightly taller, they disappear into the back ground and are going to allow 'rivets' to be installed in places where a glued rivet would be no good as it will have no strength and will avoid using an Allen Headed Bolt. Plus where the hammered in rivet reveals that it has not gone in correctly and needs replacing the will substitute.
A Cool Day to Ray (006) and a good evening to all.
