Hello All
Can anyone recommend a supplier of British Military Green paint? either gloss or matt (have not decided yet) Preferably one that comes with a spray can as I am not skilled in using airbrushes. Bear in mind I am not a professional modeller like most of you!
Also, what size rivet dolly should I use?
Thanks and in anticipation of your answers.
British Military Green Paint
- Been liked: 1 time
- Has liked: 1038 times
Re: British Military Green Paint
Ian hi. Google "Deep Bronze Green spray" and you'll get a selection of suppliers who provide paint for the full size restoration industry. This is the right colour for a post war 25 pounder. Deep Bronze Green was always gloss. There are tins of model paint available if you choose to brush paint. Regards. Stephen
Ian - I posted these mixes on the Cent section a while back:
2. From the mid 50s to the late 60s, Cents were paintEd Deep Bronze Green No 24. Mixes as follows:
- Humbrol: 6 x 2 + 1 x 33 + 4 x Revell 84
- Tamiya: 8 x XF5 + 5 x XF62 + satin varnish
- Revell: 10 x 65 + 1 x Black
- Xtracolour do DBG in a single can; x814 but the plastic boys don't seem to rate it.
- Has liked: 605 times
- Been liked: 147 times
Hi Ian
You could do worse than check out:
www.militaryvehiclepaint.co.uk
They do 400ml aerosol cans, with free P&P to mainland UK.
Kevin
Kevin
- Been liked: 3 times
Hi Ian
As a new to this hoppy as well, i spent a lot of time puzzeling over the couler & paint supplyer. I used Hammerite paint Smooth dark green,, in a spray can 400ml for £8. it worked well om my centurion. The only draw back was haveing to wait 24 hrs between coats. time well spent to get a good finnish, in deep bronze green
For OLive drab have a look at Tamiya ennamel paint range they do a 150ml spray cans, you would need about 4 cans for the 25pdr & limber kits
happy building Dave N
- Has liked: 403 times
- Been liked: 9 times
http://www.wonderlandmodels.com/media/r ... lChart.pdf may be of assistance re paints
