most likely a stupid question but..
Steen Vøler
Has liked: 62 times
Been liked: 499 times
Post by Steen Vøler »
Hi all
I was connecting my MG Led to the Benedini Armortek Sound box yesterday to get it to light up when firing the MG sound.
However - no light from MG is appearing when triggering the sound.
The config of the sounds of the Benedini was made with no wiring to the LED of the MG. I connected this afterwards.
Does the LED need to be connected to the pins of the Sound module when config the sounds of the Benedini board
NB: I did a LED check and the LED is working with normal 12v connected.
cheers
Steen
cheers
Steen
leesellars
Been liked: 15 times
Re: most likely a stupid question but..
Post by leesellars »
Hello Steen
If you have put 12v direct onto the LED. You would have blown it. The voltage of the sound unit is active all the time and put out about 2v.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Steen Vøler
Has liked: 62 times
Hi Lee
well - the bulp still works :D
Does it have to be connected to the 3-pin connector when programming the sounds for it to work?
cheers
Steen
leesellars
Hi Steen
No it don't although it matters which way round you have it on the pins.
Lee
Steen Vøler
Has liked: 62 times
hi Lee
cheers
Steen
