King Tiger (2013) No 31 is arrived in Denmark
Allan Carlsen
Been liked: 128 times
Post by Allan Carlsen »
Hello all
Just get 4 large and heavy packages. What a beauty.
Thanks too Gill for a great help in getting it delivered.
4 large boxe is arrived
John Fitzsimons
Has liked: 6 times
Been liked: 805 times
Re: King Tiger (2013) No 31 is arrived in Denmark
Post by John Fitzsimons »
I hope now that you got you first photo of the Kit you will keep them coming. :D
Allan Carlsen
Hello all
A little update from me
I need a bigger desk, I live in a apartment, there is not much room as you can see, but the first belt is now ready (90 parts) with split and bolt, will paint with TS-38 Gun Metal on sunday.
Just one question, how many part do you use to one belts ?
Allan
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
congratulations with your KingTiger Allan :D
Look forward to follow the build and also to see it running at our battledays
cheers
Steen
cheers
Steen
Allan Carlsen
Hello all tankers
Some work last night.
Allan Carlsen
Hello
Some work last weekend, primer on the turret. :D
a few soldiers keep watch over the KT
John Fitzsimons
Has liked: 6 times
Turret looks like a good fit.
Allan Carlsen
Hello John
The only problems was the turret rear, lots of file work, I'am still not happy with my work with plastic padding, I have forgotten to use hardener, and must start over again. :shock:
Allan Carlsen
Hello all
I am now workning on the hull. Did some paint and now looking for the suspension bush, I hope that they not missing between the other parts. :oops:
The suspension bar is not fully assembled, next is the floor
The Pannier floor need some primer
The hull is now assembled
Steen Vøler
Has liked: 62 times
Nice work Allan - I am sure that you will locate all parts for your build within the received packages :-)
Steen
cheers
Steen
Allan Carlsen
Hello all
At last - the Hull is now finished - done, only a few screws need to be put in pannier floor and sides. and the top fits just fine. Next is Hull Details.
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Looking good Allan. Nice to see another King Tiger coming together.
Dale jordan
Been liked: 513 times
Post by Dale jordan »
Hello Allan . Dale from Australia . Click below for my build . I would recommend that once you are happy with the fit of your hull plates and deck , that you tighten her up for good and fill all bolt holes and do all the fake welds as below with car filler , then you can prime and if you like do the top coat of colour from the panniers down , so as once the suspension is done you don't have to keep pull it apart ..Dale.
http://www.armortek.co.uk/Forum3b/viewt ... 8&start=60
Allan Carlsen
Hello Dale
Thanks for the tips. I have put the hull away, I live in apartment and don't have much space, so it does not enter again before in the new year. The car filler not available here in Denmark, but trying to find something similar.
The hull right now, weighs over 33kg, so I can not move the hull around anymore.
Just geting started on road wheels. :D
Allan Carlsen
Hello
Some work at the road weels.
about 3 kg
about 3 kg
