centurion dead
Jeff Gregory
centurion dead
Post by Jeff Gregory »
Hi guy,
Any ideas?
My tank died while driving around a level grass area, still have power to turret but no drive at all. Batteries are full charge and nothing jammed as I pushed it into the shed.
Was driving ok going strong and just stopped, not to run again. And the motors were hot.
Any help appreciated.
Jeff
Has liked: 1484 times
Been liked: 1690 times
Re: centurion dead
According to the manual, there's a "self-resetting trip" inside the speed control module, so maybe this has been tripped ?
Leave the tank to cool down and see if it will fire up again.
I don't know if it needs the power disconnected to reset, or just needs to cool down.
John Davie
Been liked: 15 times
Re: centurion dead
Post by John Davie »
Hi,
The 'trip' I'm aware of (and encountered) is current sensing, it basically cuts the speed controller and resets by itself within a couple of seconds without the need to do anything.
If it doesn't return to operation after waiting a bit then other than checking fuses and that you are getting power and the receiver signal to the to the speed controller I would suggest you contact Mark (at Armortek).
John.
Plus others!
Jeff Gregory
Re: centurion dead
hi guys,
Problem solved care of Mark, one 40a fuse blown in power supply module.
Simple and easy to fix.
sean kerambrun
Has liked: 17 times
Been liked: 7 times
Re: centurion dead
Post by sean kerambrun »
Awesome news Jeff.
I don't have my motion packs yet.. I must chase them up
Sean
sean kerambrun
Has liked: 17 times
Been liked: 7 times
Re: centurion dead
Hi Jeff
I finally have the cent running and blew the same fuse as you . And I was taking very easy as it was the first time out. Once you replaced it has it blown again?
Sean
