Panzer 4 #033
- Has liked: 163 times
- Been liked: 849 times
Panzer 4 #033
Happy day on Tuesday when UPS delivered Panzer 4 #033 to my door. Looks like a great model. I'm looking forward to building it. I don't know how long I can hold out before starting it (I have a few other projects to complete first). Thanks to those builders who have posted their great P4 builds before me!
Best regards, Bob
Best regards, Bob
- Been liked: 25 times
Re: Panzer 4 #033
Hi Bob,
I always admire your skill and there is no doubt for me, that you will build a masterpiece!!
Bodo
Bodo
Re: Panzer 4 #033
HI Bob
loking forward to your build already ,carnt wait to see some progress on it . I will be waiting for your posts and johns to see how it should be done
all the best,,,,,,,,,,,,,,,,,,,, nick
- Has liked: 1490 times
- Been liked: 1698 times
Re: Panzer 4 #033
It will be good to see you do something from the dark side of the force
Please don't stop with the M3 though
- Günter Gäbelein
- Has liked: 41 times
- Been liked: 195 times
Re: Panzer 4 #033
Hi Bob,
congratulation to the Panzer IV. Do you have already plans, which version you will build?
Günter
Günter
- Has liked: 6 times
- Been liked: 822 times
Re: Panzer 4 #033
Looking forward to seeing it go together. Good luck and start soon.
Re: Panzer 4 #033
Gosh thanks for all the nice comments guys - even before I get started!
So cool to have tank enthusiast friends all over the world.
Gunter: I'm planning an H or J model from the Normandy time frame. With Schurtzen on turret and hull. I was hoping to buy a pair of early style rear idlers from you to save me some work.
Adrian; no worries about stopping on the M5, I always have about 10 projects going at one time.
Happy building everyone,
Last edited by Robert E Morey on Fri Apr 20, 2012 6:42 pm, edited 2 times in total.
Re: Panzer 4 #033
I think mine will be either H or J also, Probably H as I am lazy. Normandy to go with Tiger. Did they have the early idlers?
Re: Panzer 4 #033
Hi all,
Its been ages since I posted anything.
I could not stand looking at the boxes for my Panzer 4 any longer, so I decided to start. I began work on the wheels. Trying to wade through the awful new Photobucket to post photos. I did some "Mr Dremeling" to remove the machine marks between the flutes of the wheels. Also added the grease fitting to the hubcap with an #0-80 x 1/8 screw. The other 6 screws are #1-72 x 5/16" flat head screws. When viewed from the front the screw should be the head only, so I will cut off the excess screw and sand them flush with the nut. I plan to epoxy all the screws into the hub cap. Also did a bit of deburring on the hub cap and chamferring on the lead in to the wheel - the caps screw in much easier now.
Not much progress, but at least I can say I started!
Best regards, Bob
Best regards, Bob
Re: Panzer 4 #033
Good to see you have made a start. Looking forward to your posts.
Re: Panzer 4 #033
John,
Thanks for the reply. Your modifications have been a greet incentive for me to get going on my P4. Perhaps we can collaborate on making the shurtzen for these someday? Your bump stop brackets are really nice. Being white metal, do you think they will hold up ok with impact from the swing arm? They look fantastic. I was trying to figure a way to slim down the kit brackets to be more realistic but you nailed it.
Re: Panzer 4 #033
I think they will be O.K. Quite a lot of metal in them. I was going to make them in brass but got lazy. If they fail I might make brass ones. I do not drive the tanks much anyway.
When assembling the hull there are a couple of screws to retain the gear case that need to be fitted from inside the hull plate. Cannot get them in after the hull is assembled.
