centurion hull holes
Ray Brown
Has liked: 26 times
Been liked: 103 times
Post by Ray Brown »
g'day all. can anyone tell me what the holes in the pics are for. i can't seem to find anything that mounts on there. am i missing something.
neil pudney
Re: centurion hull holes
Post by neil pudney »
Hi Ray, looking on page 24 of the instruction manual it looks to me these are the holes made for attaching the return rollers that go above the main wheels. I havent got to the stage of build you are at so had a quick look at the instructions where you can clearly see the holes on the pictures and when i got to page 24 i can now see what they are for.
best wishes,neil
neil pudney
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day neil. thanks for your reply but i'm talking about the 2 small holes between the road wheels on the lower hull.
cheers
ray
neil pudney
hi ray, yes saw those and they have got me wondering as well, the best thing to do is send mark at armortek a message when they are back from their break, he should know !
all the best neil
neil pudney
mick whittingham
Has liked: 10 times
Been liked: 226 times
Post by mick whittingham »
Hi Ray,
those two holes are for the side skirt stay arms. There are three down each side to support the lower edge of the side skirts. The first is right at the very front where the hull angles up to the idler roller and the other two are spaced further back.
You should have six pieces of heavy gauge steel bar with a short bend on each end and drillings in for mounting. These are the stay arms.
This should help, but only after you mount the mudguards on which the skirts are fitted.
Regards,
mick
Ray Brown
Has liked: 26 times
Post by Ray Brown »
g'day Mick. thanks very much for that. that cleared it up for me.
cheers
ray
