2010 Mid Tiger
Ian Jeffries
2010 Mid Tiger
Post by Ian Jeffries »
Unfortunately due to circumstances outside of my control i regretfully need to sell my 2010 mid Tiger 1
It is untouched although all boxes are open but i can easily repack.
Included are Tiger 1, motion-sound-smoke-blank firer.
Also included are over £5000s worth of extras from Tim Catton, Hugo Stitch, Steve Winston, Mike Stannard, Brian Leach
And finally around 30-35 books purchased for my build i cannot remember the exact costs but im sure it was in excess of £500.
I can deliver within 100 miles of dartford easily included in the price.
I am looking for a quick sale so offers of £4500 ovno will be considered.
I am away until Monday PM so i will not be ignoring PMs just unable to answer.
I will be able to compile a full list of extras but not until Mon-Tue.
Ian Jeffries
Ian Jeffries
Re: 2010 Mid Tiger
Hi
Below is a list of most of the parts that are inc in the sale. Again these are all still boxed.
Tim Catton
1 x shovel early type
1 x Track Hammer
1 x Tetra 2 fire extinguisher
1 x Wire cutters
2 x 88 Shell crate
1 x Axe+ head cover
1 x Tool Box + clamps
Post
Brian Leach
Cast towing Shackle
Hugo Schittlich
Muzzle Brake
Paul Morris
Filler caps
Steve Winstone
Bump Stops
Tiger Convoy Light - 1
Tiger Reflector - 1
Tiger MG Barrels - 1
Tiger - 20 Ton Jack - 1
Tiger - Working Jack Brackets
Tiger Exhaust - Heat Shield Set (2ea)
Tiger Steel Ariel Tube -1
Tiger Rear Mount Tool Box -1
Tiger Exhaust Pin Caps - 4
Tiger Grenade and Smoke Dischargers- 1
Tiger Starter Plate - 1
Tiger 3mm Castle Nuts
Mike Stannard
Nut Lock Tabs x 25 Hole Dia .120" Tab Dia .280" Fits 4-40 & M3 x 2
Nut Lock Tabs x 25 Hole Dia .090" Tab Dia .270" Fits 2-65 & M2 x 2
Nut Lock Tabs x 25 Hole Dia .090" Tab Dia .200" Fits 2-65 & M2 x 2
Tiger 1, 2 & Jagdtiger Hammer (Metal Head Wood Handle)with fittings
Tiger 1 & 2 Axe (Metal Head Wood Handle)with fittings
Tiger 1 Shovel Short Handle (Metal Head Wood Handle)with fittings
Tiger 1 Wire Cutters (Metal) with fittings
Tiger 1 Pry Bar (Metal) with fittings
Tiger 1 Tank Tow Ropes, Brass/Wood Cleaning Rod p-etch/bronze cast fittings
Tiger 1 & 2 Jack Block Set Assembled Wood Block Brass Photo-etched Fittings
Tiger 1 Starter Crank Set
Tiger 1 'U' Shackle Set of 4
Tiger I, II and Jagdtiger "C" Shackle Pair, with working wing nuts.
Tiger 1 Engine Tarp Tie Downs Set of 12
Tiger 1 Spare Track Clamps Set of 7
Tiger 1 & 2 MG Mount and Cupola Ring
Tiger 1, 2 & Jagdtiger Track Tow Rope Late Version with brass p-etched fittings
Tiger 1 Driver and Radio Op Deluxe Hatch Set
Tiger 1 Escape Hatch Jul 43-Feb 44 (Flat hatch plate with 3 bolt hinge base)
Tiger 1 Turret Ring Guard
Tiger 1. Sternantenne D Deluxe Set
Tiger 1. Single Flat Bar Track Link Stowage
Tiger 1 and 2 Air Vent Late Type Deluxe Set
Tiger 1 Front Mudguards
Tiger 1 Rear Mudguards Late Type
Tiger 1 Engine Grill Covers Set of 4
Tiger 1 Driver/Radio Op Periscope 1 Unit.x 2
Tiger 1 Turret Stowage Bin (Assembled)
Tiger 1 Snow Shovel
Tiger 1 and 2 Armortek Upgrade, Kit T1 Late
Tiger 1 and 2 Periscopes Cover Kit
Tiger 1 & 2 Late Production Deluxe Loaders Periscope Assembled
Fire Extinguisher Set (Late Type)
Antennenfuss (flexible base) w/out wing nut and strap x 2
1.4m Stab Antenna with strap and wing nut.
2m Stab Antenna with strap and wing nut. x 2
Large Swastika ID Flag 6" x 13"
Small Swastika ID Flag 6' X 7"
Large Balken Cross ID Flag 6" x 13"
Small Balken Cross ID Flag 6' X 7"
88 mm Kw.K 36 Empty Painted Brass Case x 4
88 mm Kw.K 36 AP Round Painted Brass Case & Resin Projectile x 4
88 mm Kw.K 36 HE Round with Brass Case (All Metal) x 4
88-SC01 88mm Round Steel Container x 3
Tiger 1 88 mm AP Round Decal set of 6
Tiger 1 88 mm HE Round Decal set of 6
Tiger 1 Track Tow Rope Early with photoetched & bronze cast fittings
Tiger 1 Loaders Hatch Set
Tiger 1 Escape Hatch Dec 42-Jul 43 (Beveled hatch plate with 3 bolt hinge base)
Tiger 1. Drum Cupola Assembled Set
Tiger 1 Air Vent Early Type Deluxe Set
Tiger 1 Rear Mudguards Early Type
Tiger 1 Feifel Air Filters
Tiger 1 Rear Deck Engine Covers Latches Set of 3 as a Kit
Tiger 1 Rear Deck Center Cover Prop Open Latches Set of 2 as a Kit
Barrel Rifled Plug for 88 mm guns
Richee Wignall
Various Muzzle Bags
Glass Prisms and a few various parts
Ian
Ian Jeffries
Re: 2010 Mid Tiger
Tiger is now sold.
Many thanks to all those who enquired.
Ian
John Fitzsimons
Has liked: 5 times
Been liked: 788 times
Re: 2010 Mid Tiger
Post by John Fitzsimons »
Not surprised. Would have bought it myself if I did'nt just get another late tiger. Good luck to the new owner.
Bob Gould
Been liked: 31 times
Re: 2010 Mid Tiger
Post by Bob Gould »
Knew that wouldnt last long :D
Ian Jeffries
Re: 2010 Mid Tiger
Hi Everyone
The Tigers back up for sale. Please only make an offer if you have the money. Its not fun wasting mine and
Other peoples time buying items you have no way of paying for.
The price is still the same £4500 gbp delivered within 100 miles of Rochester.
Ian
dennypatterson
Been liked: 1 time
Re: 2010 Mid Tiger
Post by dennypatterson »
is it still for sale,? with all the bits, if so could look up next thursday 11 october with cash to collect, any discount for cash and collection? 01749 830321
Richard wale
Been liked: 3 times
Re: 2010 Mid Tiger
Post by Richard wale »
Hi is the Tiger still for sale give me a call on 07939104238 to discuss.
Thanks Richard.
