Ultimate Panther/Jagdpanther Build
Re: Ultimate Panther/Jagdpanther Build
HI Mick
looking good its becoming a real beast , good job you got the lift to help out
best wishes ,,,,,,,,,,,,,nick
- Has liked: 5 times
- Been liked: 682 times
Coming along nicely. Just noticed that your Jagdpanther is in the Panther rather than the Jagdpanther section.
- Has liked: 1564 times
- Been liked: 835 times
Hello John, thanks for your mail. I posted my build in the Panther Section because the first part of the construction is around the Panther hull.....with the upper hull as the Jagdpanther option. I had thought of moving the build to the Jagdpanther section.....it was easier to leave things as they are. I have enough trouble with my computer as it is.
Progress is slow at the moment......to many other distractions
Managed to spray the undercoat yesterday, the weather is cold and damp, so, it's an inside job.
- Has liked: 133 times
- Been liked: 784 times
Mick,
Like John suggested, I recommend at some point of putting a piece of plywood on top of the lift. The plywood should be wider than the tank. My lifts are narrow like yours, and tanks can easily roll or slide off the metal surface. I screw the plywood down to the top of lift as well to prevent the whole thing from sliding off. Nobody will be happy if 100 lbs of tank slide off the lift onto the floor.
Another option to get it out of the house/room; put carboard down on the floors and drive it off the lift out of the house on its own power. If the motors are not installed it can be pushed and rolled fairly easily.
Your JP is looking great, keep up the fine work!
Thank you for your replies John and Robert, I will follow your advice. I have obtained a sizable piece of plywood.
I have attached a few photo's. The Clarke Table Lift was easy to push into the small bedroom....as you can see the problems arise when trying to exit, with the Jagdpanther on board the table lift.....The final fitting out will take place in the main workshop/dinning room.......
As you can see...there is no way the tank is coming out.....so, I have a cunning plan, remove the upper hull, push the lower hull down a short ramp, then, use my 'sack truck' to bring the lower hull out of the bedroom and into the main dinning area, yes......
Resited the Jagd' back, I will work on the upper hull, before the final move into the main workshop.....a bit trival I know.....I just like taking photo's
- Been liked: 223 times
Hi Mick
Very impressive beast she looks from your photo's Mick,not easy to squeeze past
when the door bell rings
Kind regards to the lady who issues permissions and Visa's for travel.
I would'nt dare put photos of the house on at the moment. Home alone for a month. The whole house is a tank workshop. Sooner the better I build a proper workshop.
If you get a chainsaw tou could make a bigger doorway.
Thanks Phil, I will pass your kind regards on.
I am enjoying this build, slow but enjoyable. Fitted the 'Steve Winstone' upper tool box. Had a real problem when drilling the back plate.....the drill bit 'ran' out of line, I think it's because the alloy plate is a 'soft' metal. Anyway, out came the Milliput.....job done. Steve's parts are well worth adding to the build.....way beyond my abilities. Charged the Comet up...was hoping to take it to a 'Show' tomorrow , thunder storm will hail at the moment.[
Nice work Mick,
It does look good.
Hope yoe are wrong with the weather
It does look good.
Guess what......go on, guess......I managed to maneuver the table lift, with the Jagd' lower hull on board.....out of the small bedroom.......Yesssss!. Ok, marked the hall wall in a few places, nevertheless, job done. The workbench is now ready for further building work......
Welldone Mick
Have the marks on the wall been seen by the Commandant
Or a quick touch up job to disguise.
