Few news from Italy
leesellars
Been liked: 15 times
Re: Few news from Italy
Post by leesellars »
Hello Andrea
Looking good. Just something ive picked up. For the reciever you must not have a voltage above 5vdc. This is due to the fact that the TBS5 sound card must not go above this voltage as recommended by Thomas. This will distroy the card.
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Andrea Daviero
Been liked: 5 times
Post by Andrea Daviero »
Hi Lee, I installed on my halftrack the TBS mini sound board (works till 12V I think), it has same functionalities as the TBS5 plus USB connection for customization.
The only different thing is about connecting it to an external amplifier different from the benedini ones.
I had no problems with the board itself, I have only a noise that I must filter as soon as I will re-route wires for the final setup.
I had also few problems with the power, in these hot days the armortek power module just turned off when in use, I checked battery voltage and never went below 22.08V under stress (I have a logger connected wich will show me the lower value), also that happened completely random if I was running or not, near or far, climbing or descending.
I think it is an heat problem, I will check when temperatures becomes a bit warmer.
In case I find that temperature is the cause I will open the armortek module and add a fan or an heat sink. ;)
Andrea Daviero (Andrew)
Been liked: 3679 times
Hello Andrea
The Armortek power supply module does not generate heat. The problem you are experiencing sounds more like a loose connection. The Armortek amplifier module can get warm if used for long periods, but this system is protected and will reduce the sound level until the unit cools.
Andrea Daviero
Been liked: 5 times
Hi Mark, I have on my halftrack only the motion pack without sound module (so no armortek amplifier, and the benedini one is installed in the engine compartment.
I know that power supply generates only few heat, probably only from the main relay, but the last time I used it was outside, with a sunny day and an outside temperature of about 40-42°C, maybe that inside the halftrack the temperature was very HOT, over 50°C, that could create problems.
I tried some tests in the same day with a bit colder situation (mid-late afternoon) and had no solutions to the problem. I was unable to replicate under stress condition. I will check the wires as soon as I will decide if I do flakvierling conversion or not. ;)
PS: Thanks for the answer ;)
