Adjustable torsion bar suspension.
Has liked: 1485 times
Been liked: 1695 times
Would Mark be able to provide a posting showing how the adjustable torsion bar suspension works in the new Late Tiger ?
Been liked: 3700 times
Re: Adjustable torsion bar suspension.
Hi Adrian
I'll throw some words and pictures together for you in next day or two.
Cheers Mark :D
Adrian
Hi All
Not the easiest of things to describe this, but here goes.
LATE TIGER 5MM X AXLE.JPG (140.4 KiB) Viewed 1666 times
The axle, suspension arm and suspension shaft are unchanged. The torsion bar is supplied with flats pre-ground on each end. At the fixed end a short shaft, looking like the suspension shaft is fitted to the torsion bar and into a counterbore in the suspension bar on the other side. This fixed end shaft is secured by a single high tensile M6 cap head passing through the hull side and suspension bar and into the end of shaft. To adjust the angle of the suspension this single bolt is loosened, the angle adjusted, and the bolt retightened to lock into place. It works because the the twist load from the torsion bar acts to furrther tighten this single screw.
Paul Morris
Been liked: 68 times
Post by Paul Morris »
Hi Mark.
I like it! so assuming that in time your tank may, or could settle due to weight of batteries etc etc you can now simply losen the above mentioned bolt and re set your suspension any time?
Clever ans really simple what a good idea.
Cheers Paul :wink:
01524 720977
Hi Paul
Yes you are correct.
John Fitzsimons
Has liked: 6 times
Been liked: 813 times
Post by John Fitzsimons »
Great idea mark. Well done.
