Sherman BARV
David Skeldon
Has liked: 33 times
Been liked: 312 times
Re: Sherman BARV
Post by David Skeldon »
Hi,
She will be able too when its finished.
Has liked: 161 times
Been liked: 830 times
Re: Sherman BARV
I would hate to jump into 9 foot deep water to hook up a tow bar. So its more or less a dissabled vehicle bulldozer. :D
Thanks, interesting critter.
Re: Sherman BARV
a remarkable model david, as have all the shermans so far you have built, unique and interesting. thanks for posting. regards simon manning,
David Skeldon
Has liked: 33 times
Re: Sherman BARV
Hi,
First time out side,
Paul Morris
Been liked: 68 times
Re: Sherman BARV
Post by Paul Morris »
Brilliant David.
So different to anything else out there, will you be taking it to the open day? would be great to see it up close.
Cheers Paul :wink:
01524 720977
David Skeldon
Has liked: 33 times
Re: Sherman BARV
Hi,
Thanks,I hope too ,But close up it is no way near the superb work that you do.
Paul Morris
Re: Sherman BARV
Hi David.
Thank you very much for that . . . but I stand by what I said you have created a one off model all on your own that looks the business and is very impressive well done indeed.
Cheers Paul
01524 720977
David Skeldon
Has liked: 33 times
Re: Sherman BARV
Now have something to recover.
martin pitcairn
Has liked: 795 times
Been liked: 8 times
Re: Sherman BARV
Post by martin pitcairn »
David, these are 2 excellent conversions, you should be extreamly pleased with the results. keep these comming.
Re: Sherman BARV
your models david are outstanding, always something different, the BARV inspired me to read up about it, interesting, thanks for posting some photo's, regards simon manning.
Fabrice Le Roux
Been liked: 14 times
Re: Sherman BARV
Post by Fabrice Le Roux »
David,
Super model.
But one can see why the Comet drowned... no wading gear!
Bet the Beach Master had something to say about that.
What are you comtemplating next?
cheers, Fabrice
David Skeldon
Has liked: 33 times
Re: Sherman BARV
Water test
Has liked: 1484 times
Been liked: 1687 times
Re: Sherman BARV
:shock: :shock: :shock: :shock: :shock:
:D
Adrian
Nick Farrugia
Re: Sherman BARV
Post by Nick Farrugia »
HI DAVID
that is brilliantly unique :D was there any water inside the tank after, is it completly watertight or have you got electric pumps to pump out any water that creeps in it is very good congratulations ,regards ,,,,,,,,,,,,,,,,nick
David Skeldon
Has liked: 33 times
Re: Sherman BARV
Hi,
A little bit got in ,But not enough to be a problem even after 15 runs thru the water.
