Motion and Special Effects Pack update
Been liked: 3712 times
Following modification, the new generation firing unit has been rigorously and successfully tested with excellent results.
Follow this link to see the unit in action:
http://www.armortek.co.uk/html/shopeu/s ... erops.html
and click on the wording:
See the Blank firer during testing here
Gill
Matthijs Dijkstra
Been liked: 2 times
Wording
Post by Matthijs Dijkstra »
Hi Gill,
I tried clicking on the wording but nothing happens?
Matthijs
Martin Cohen
Been liked: 1 time
Post by Martin Cohen »
hi Matthijs, I found that the video comes up as a Flash presentation within a pop up window. Make sure your browser is enabled to show .swf, and allows pop-ups too.
Hope that helps!
M
Matthijs Dijkstra
Been liked: 2 times
Pop-up
Thanks Martin but it still doesn't work!
B.r.
Matthijs
Graham Ord
Has liked: 4 times
Been liked: 16 times
FIRING MECHANISM SOUND
Post by Graham Ord »
Matthijs
Perhaps you were caught out like me at first!!!
Click on the link
http://www.armortek.co.uk/html/shopeu/s ... erops.html as they suggest, when you are on the new page you should see a new link about halfway down that page.
Click on that.
Graham
Matthijs Dijkstra
Been liked: 2 times
Link
Thanks Graham. It worked and I have seen the clip! Looking good!
Matthijs
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Mark and Gill
Do you know anyone who makes a 24v to 5 volt converter as a stand alone unit or could you provide one for those of us on the older designed control boxes.
I see its a feature of the new control box...
David Ward
Post by David Ward »
Hello Derek
An easy round it is to use an Electronize speed controller fitted with a BEC to operate the turret rotation motor and hence also supply the RX.
Derek Attree
Hi David
The speedcontroler for the turret in the Panther is electronize
I am not sure if it has a BEC, and I cant get to the box (Still not unpacked)
at the moment as I am having a bit of work done at home
and the workshop is a bit full at the moment!!!
What sort of amps do we need on the 5 volt line for the recever & sound unit
etc....?
