Ultimathe Panther by Luca
Has liked: 161 times
Been liked: 830 times
Luca,
Your Panther wheels, sprocket and hull are looking really good. Its going to be a masterpiece I can tell. Keep up the great work.
I threaded a few of the track pins, no all of them yet. It is very handy if you need to take the track off to just remove a nut and washer. You may want to Loctite the nuts as they may loosen themselves over time.
Great work,
Luca Fossa
Post by Luca Fossa »
Back again my dears
Just some pics to show my progress. The two rostrum of the rear starter plate come kindly from Steve Norris.
The pics are a bit yellow because I have switched a spotlight but in someone you can see the real color, hope you can enjoy.
If something doesn't sound good please report me
Cya all
Luca
Has liked: 1484 times
Been liked: 1687 times
Superbo !!
Adrian
Luca,
excellent looking details. It looks like you are taking some painting tips from our current master Simon. Excellent weathering on the wheels.
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Beautiful details-very nice!
Brian
Luca Fossa
Robert E Morey wrote:Luca,
The secret is watching and try to learn :D :D :D :D :D
yves mouton
Been liked: 741 times
pictures
Post by yves mouton »
Hi Luca,
Maybe you can help me, i wanna look at your pictures of your
panther build but all i see are red crosses instead of a picture,
normaly if i click on the cross the picture comes up but now happens nothing?
regards Yves
Luca Fossa
Unfortunately i've no idea Yves but, anyway, i can send you the pics by mail if i can have yours
Luca
John Fitzsimons
Has liked: 6 times
Been liked: 812 times
Post by John Fitzsimons »
Excellent job on the wheels. Well done.
Luca Fossa
Hi guys, some pics about my panther and my work….many details have to be adjusted yet
Il frontale dopo la verniciatura
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Luca.
Your doing a great job on your Panther, I like the way you have put the recessed bolts in the engine deck.
Marcel de Groene
Post by Marcel de Groene »
Hi Luca,
Great job on your Panther. Your exhaust look like an early G but you use the original parts from Armortek. Can you explain because I have seen so many exhaust versions I'm confused :? . Is it original to use the bottom part(Armortek) with home made or third party exhaust pipes and covers. I want to change mine to an early model and if this is original I can easily transform my own exhaust.
Stay on tracks
Luca Fossa
No Marcel, the squared bottom provided in the kit is referred to the middle/late "G" version. The rounded bottom was used commonly in the early "G" version. What's really different from a version to another is the bar retainig the exhaust at the top.
What i have choose (to use the parts provided in the kit over all) is the exaust adopted in the transiction between middle-late version where exhaust's pipe was substitute from the "flamelichter".
Now can't be more specific but later i will post a drawing more explicate.
Luca Fossa
Hi Marcel, here are my references for the Panther’s “Gâ€
some good stuff going on there luca and making quick progress, all the best simon,
