Once I'd fitted the gear cases to the front sides of my Panther, I noticed that they were binding on the hull.
I then read the 'Official Technical Advice from Armortek' section of the forum that deals with this problem, printed it off, and am now in the process of re-doing the driven gear cases as per the advice.
My question is, if all else failed, would it cause a problem if I made up a thin gasket between the hull and the case, to just get that extra minute clearance?
[/u]
Concerning binding drive gears.
- Been liked: 741 times
gasket
Hi Darryl,
I think there a 2 gaskets in the kit for sealing the drive case to the hull. In my tiger 1 kit where these included in the kit.
Beware that the bearings fit good at the inside of the drive case
regards Yves
regards Yves
