Correct shade of OD
Dale jordan
Been liked: 525 times
Post by Dale jordan »
Hello David . Go to your hobby shop and buy a tin of Humbrol 75 . Do a test spray on some small parts . Make sure that you use the same primmer as you are going to use on your model first . I Always add a little humbrol gloss to the paint . As the flat paint tends to pick up finger prints . Dale.
Dale jordan
David here is a photo of the repaint I did on my jeep ..Useing humbrol 75 with 5% gloss , I then lighted up the same colour with a little humbrol dark yellow and sprayed this onto the centre of the main pannels at the same time useing a Double action air brush . I hope this helps . The main thing is to test spray first to make shore that you are happy with it before you start on your half track . Dale
Dale jordan
This is how the finnished colour looks on my jeep , sitting next to my Sherman as you can see my Sherman would look good painted this way . David I tryed about 15 types of hobby paint , this was the only one that had that olive shade to it !!! . The others where to green . Dale
Dale jordan
Has liked: 165 times
Been liked: 849 times
Dave,
I like Testors (ModelMasters) 1911 Olive Drab spray. It is available in a three pack of small cans. Its a bit spendy ($13-$15 for three cans) but its good looking OD, and many on this forum have said its authentic color. I think it is a good match myself. Its available in USA by mail order from http://www.squadron.com/ Your local hobby shop should have it too. The Testors gunmetal spray (also available as three pack) is ideal for tracks and MG's as well.
Carlos Vollenweider
Been liked: 13 times
Post by Carlos Vollenweider »
Hello Dale,
I have watched your posts for some time with great admiration. I was floored with your scratch built Panther, and of course your Armortek early Tiger I. Your study of the M4 is outstanding, especially with the protective upgrades you've added. The semi-gloss/egg shell on the Jeep is amazing. Paint work and weathering is my weak suit. I am one of the slow builders still assembling parts. I will post pictures of my mid Tiger I build soon. Thanks to you, and the other super builders on this site.
Birt
Tony Read
Post by Tony Read »
David,
The Tamiya OD is probably the closest match to factory fresh paint you will find. But to be scale it needs just a dash of yellow. For that weathered look spray random patterns of OD with slighly more yellow in the middle of the panels and slighly less on the outside. BTW it MUST be matt as per US regulations. Add stains with washes of oil paints and add scuffs, scratches etc and that will be one tastey halftrack. Matt paint on full size vehicles marks badly, that is why you see restored vehicles with a semi-matt finish, including mine. Sorry if this is teaching you all to such eggs, but it works for me. I have about 20 litres of a 'faded' OD in synthetic for my 1:1 halftracks, if someone wants a bit they are welcome.
For T19 halftrack restoration project go to: http://myweb.tiscali.co.uk/stourvalleys ... rack_1.htm
Lucien Runge
Post by Lucien Runge »
One of my acquantances works for Testors Corporation. His advice is to mix the Testor's enamels with 20-30% polyurethane varnish. This will increase wearability/durability of their paint formula. I tried it on one of my helmets. It really does make a difference. He suggested that the finish on my Sherman should be handled in the same way...food for thought for all you guys out there jostling with this issue.
Lucien
"Say 'ello to my little friend!" - "Say goodnight to the bad guy", Scarface
Has liked: 1495 times
Been liked: 1699 times
I'm trying to order some OD for my Sherman and am having problems arriving at a RAL number for the supplier to work to.
The thread here, and my friend Google, gives Humbrol 75 as the correct shade.
The problem is that I've only found one comparison site which includes Humbrol 75 and it equates it to RAL 6031. Then I can't find anywhere which will display RAL 6031 as a valid colour - it always seems to be missing from the colour chart :evil:
The RAL colour called Olive Drab, 6022, looks brown to me :shock:
It is mail order, so although I could post them a tin of Humbrol, it would be easier to provide them with a RAL number :!: :!:
Ad Wouterse
Been liked: 2 times
Post by Ad Wouterse »
Hi Adrian,
Here you will find a colour sheet with most RAL codes (incl. 6031) http://www.csprocessing.co.uk/ral-colours.php or http://www.easywind.de/nl/de-dienst/ral ... tabel.html
The "original" colours are a permanent source for discussions on most modelling sites. To complicate matters, photographic reproduction of colours may deviate from the real paint colour.
You could consider to order a classic colour fan deck from the German RAL institute http://www.ral.de/en/ral_farben/farbkar ... .php?id=46
Good luck :wink:
Ad
Hi Ad.
The paint arrived today and, after a trail spray on some scrap material, I'm very happy with RAL 6031 as a good dark, not-too-green Olive Drab.
The other paints I ordered were completely wrong though :cry: , so I've ordered a RAL swatch as using the PC screen is obviously hopeless :evil:
Having said that, one of the colours may be close enough to RAL 8020 Braun for me to use on my Tiger :D
Mike Gormley
Has liked: 5 times
Been liked: 6 times
Post by Mike Gormley »
Gentlemen,
The US government certifies Testors # 1911 OD as the match for the OD used on WWII US armored vehicles.
I painted my Armortek Sherman with it and then asked my father for his opinion as he is a WWII veteran and was a QUAD 50CAL gunner and he agreed it looked the same as what he remembered
Just thought I would share this info with all of you.
Mike
