Steve,s Panther build
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Nice behind Steve... :shock: :wink: :D
Very skilled works there mate.
Keep the photos coming please.
It´s all in the details!
Has liked: 1475 times
Been liked: 1674 times
Lovely details Steve.
Where do you find such a mix of fastener sizes ?
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Adrian.
Most of my fasteners come from Macclesfied model engineering supplies, They are fairly local to me and the best thing is that i can go and trawl through their fastener racks and pick what i need (No guess work needed).
They do have a online service but i don,t know if they have anything that EKP cannot supply.
That's interesting, as I use Macc Models as source for some of my fasteners already, as well as brass sections :D
Has liked: 158 times
Been liked: 830 times
Steve,
Excellent detail on the pipes and bins. Your efforts look excellent. I like the texture you put on the pipes themselves - it will look great once "rusted" and weathered. Keep posting your work, great inspiration for the Panther crowd..
Steve Norris
Has liked: 8 times
As the rear plate is now almost complete i have decided to do a bit of work on the hull sides. I found that the gear cases looked a little plain and could do with a bit of detail adding, I started by reprofiling the mounting flanges and adding new mount bolt positions, Coresponding threaded holes have to be drilled and tapped into the hull side plates. I next added a couple of reinforcing ribs to each housing and what i think may be an oil drain port. a final bit of texturing was added to produce a cast appearance. Although the end results are not an exact copy of the originals they do look a lot better.
I will have to wait until after final assembly to see how much of this extra detail is visable.
More to come
Steve,
Excellent work, your modifications add a lot of detail. I don't know if anyone has attempted this mod before. Bob
this is the first time iv'e seen this mod on the forum, i was tempted,but changed my mind,to difficult for me, well done steve, regards simon manning,
Steve Norris
Has liked: 8 times
The next part added to the left hull side is the "Anschlagblock", This fits around and below the first swing arm on the left side of the hull. I think the purpose of this was to stop the swing arm which points forward being pushed down to far and breaking the torsion bars if the track bunched up on top of the road wheel. This could occure if the track broke when driving forward. It was not neccessary to fit a stop on the right side as the swing arm pointed backwards.
Also shown in the photo is the gear housing which is a temporary fit and the bump stops provided by Steve Winstone.
The next shot shows the swing arm and how it hits the stop when deflected down.
The final shot shows both hull sides with Steve winstone,s bump stops fitted.
More to follow
Brian Leach
Been liked: 3 times
Post by Brian Leach »
SWEET!
Nice build
Did you make the part from scrach?
Looking forward to your work
Thanks for sharing!
Brian
Brian
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
SUPER DUPER SWEET! :D
Just awesome Steve.
this is getting very impressive steve, getting the most out of the kit and forming it into a 1/6 scale replica, excellent to follow! regards simon.
John Fitzsimons
Has liked: 6 times
Been liked: 797 times
Post by John Fitzsimons »
Excellent work. Great mods.
Kent Wiik
Has liked: 6 times
Post by Kent Wiik »
Nice Steve!
I have also had this one on my "wish list" but was unsure if there was enough space between the outside hull / swing arm to make the LS 2:nd Anschlagbock, I regarded the bolt heds might be a problem.
Can you or anyone else please say how much free space there is?
Most of the nice details at the hull sides are in fact almost invincible behind the row of wheels but this Anschlagbock low in its position is actually visible...from the front...but you need to get down (a lot :oops: ).
That’s why I want one on my Panther and I am glad you Steve took the lead here.
(Btw, did you add the locking tabs? :wink: )
Steve Norris
Has liked: 8 times
Gents,
Thanks for the kind comments.
Kent,
There is a 4mm gap between the swing arm and hull side, i have used 3mm aluminium plate to make the Anschlagbock with the M3 bolts recessed into the plate. Its a bit tight but it will fit.
I have not added the lock tabs yet :shock: but will try to get some fitted soon.
