Turret spare track holders
- Been liked: 516 times
I've just been test fitting the turret spare track holders onto my 2010 tiger turret . Can someone who has fitted them ! tell me how they hold the track links on without them falling off ..Dale
- Has liked: 6 times
- Been liked: 822 times
- Been liked: 741 times
turret spare tracks
Hello, Dale and John
I put the turret trackholders and the spare tracks with
a two component epoxi resin on the turret.
The epoxi is from Bizon and is transparant epoxi and it comes in a syringe. You have to mix the epoxi for about 2 minutes.
Uploaded with ImageShack.us
Hope this explanation will help you
regards Yves
regards Yves
- Been liked: 177 times
- Been liked: 1 time
Thanks everyone . It's a hard to know what to do . I'm not that keen on drilling seven holes in the turret . We don't wont them falling off all the time , in most photos of tigers with track hangers you don't see to many photos without spare links on the turret . Some times it nice to remove things from our models to give them a different look ...
- Has liked: 8 times
- Been liked: 701 times
The method i used to attach the links on my last Tiger was to drill a very small verticle hole in the upper link holder were it touches the link and a coresponding hole in the end of each spare track link, Next i glued a short length of brass rod into the hole in the track link holder so that it protrudes about 3/16" below the link holder. If you get the length right you can still remove the links by hinging the holder up and when hinged down the rod is not visable.
Sorry i dont have any photos as it would be much easier to explain.
Hope this helps
Hope this helps
