Comet 2010-027
- Been liked: 15 times
- Been liked: 223 times
Comet
Hi John
I like all the work you have been putting on your Comet with the welds
and textures.
and textures.
- Has liked: 10 times
- Been liked: 224 times
If anybody wants 10ba nuts & bolts try Blackgates Engineering 01924 466000. £12 + vat + pp per 100 or they do 10's and 50's. I get a lot of my supplies from them. I have done the sane as John but I just cut mine off and riveted them over also done the sprocket covers with countersunk 7 ba nuts and bolts, Hoping to do something with the sprocket cover fixing to make it look more authentic. Have also used countersunk nuts and bolts for deck scopes as according to photos that what was used. Was going to supply some photos but camera is in the car and the wife has gone out in it for the day.
Dennis.
Dennis.
Hi Dennis,
I used 10BA (I think) hex bolts on the sprocket covers although I didn't go to the extreme of drilling and lock wiring them as the pictures I have of the real thing show! I too have used countersunk slot headed bolts in lots of places as the photos I have show these seemed to be a common fixing at the time of the Comet.
- Has liked: 163 times
- Been liked: 849 times
Thanks Bob,
I've had it running since I put the hull together and it seems to run well, but it's too wet and muddy to to do much running yet as I don't want to get it dirty until I have finished the painting and basic weathering. After that, like all my stuff, it can get as dirty and muddy as it wants - all adds to the effect!!!
- Has liked: 116 times
- Been liked: 1106 times
Hi John,
Sorry to be a pain but the extinguishers go the other way up,
Dave
Dave
www.armorpax.net
- Has liked: 1491 times
- Been liked: 1699 times
- Has liked: 1040 times
Your cast steel effect looks great - very necessary for the Comet.
If I may offer a suggestion, I've used UPOL High #5 which is readily available in a well known motoring store. It's designed to be a high density primer but you can spray it at various thicknesses and achieve some very subtle effects, including the marks of rolled steel (some of the Comet was cast and some plates were RHA - rolled homogenous armour). It's a sort of Mr Surfacer 500 on steroids (and a lot cheaper).
If you want to see the effects, I've put some photos on page 19 of my Pz III blog.
My Comet options pack arrived today, so I'm all set to start - in a year or so when the Pz III is finally finished.
All the best.
All the best.
